[petsc-dev] Picard with TS
Mark Adams
mfadams at lbl.gov
Tue Jan 3 07:29:43 CST 2017
> > But I see that IFunction is not correct. I am solving du/dt - C(u) = 0.
> Do you mean du/dt - c(u)* u = 0?
yes,
> > My IFunction applies C(u)*u, but LandSNESFunction should just return
> zero, maybe?
> If you are solving du/dt - c(u)*u = with backward Euler then it can be
> written as
> u^{n+1} - u^n
> ------------------ - c(u^{n+1})u^{n+1} = 0
> dt
> or (I - dt*c(u^{n+1})u^{n+1})u^{n+1} = u^n
OK, this makes sense, but I think I can use backward Euler as you say
below. I am just trying to match what others are doing to make sure that I
am not missing something algorithmically. They are using BE, as I recall
now. I am now using C-N now. I think I can assure myself that BE with
Newton is pretty much the same as Picard and BE.
> Which is the standard form for PETSc's Picard iteration; so you would
> provide I - dt*c(u^{n+1})u^{n+1} as the compute matrix J() and u^n as the
> b() Note that the b() is a constant independent of the unknown u^{n+1}.
> But I do not think it is possible to use TS to solve it this way, you
> need to use SNES and manage the time-step yourself. Trying to call
> SNESSetPicard() inside the TS won't work I think. Perhaps Jed or Emil have
> better thoughts but I think it would require some additional plumbing in TS.
> You can also discretize du/dt - c(u)*u with lazy person's backward Euler
> as
> u^{n+1} - u^n
> ------------------ - c(u^n)u^{n+1} = 0
> dt
> thus giving the linear system (I - dt c(u^n)) u^{n+1} = u^n but then you
> need to be sure it is a stable scheme with some accuracy, which it may not
> be. Again this you can do with KPS but not directly with TS I think.
> If you really are solving du/dt - c(u) = 0 then backward Euler gives you
> u^{n+1} - u^n
> ------------------ - c(u^{n+1}) = 0
> dt
> (n^{n+1} - dt c(u^{n+1}) - u^n and the logical solver is Newton because
> the Jacobian of this is
> I - dt J(u^{n+1}) . This you can give directly to TS, but using Picard
> doesn't make much sense since there is no natural A(u^{n+1}) u^{n+1} term.
> But now I remember something Emil showed me. If you can write c(x) = A(x)
> x + f(x) then you can do another lazy person's backward Euler with
> u^{n+1} - u^n
> ------------------ - A(u^{n+1})u^{n+1} - f(u^n) = 0
> dt
> Resulting in
> (I - dt A(u^{n+1}))u^{n+1} = u^n + f(u^n) and use SNESSetPicard to solve
> (again without using TS).
> Or if you only want to solve a linear system using
> u^{n+1} - u^n
> ------------------ - A(u^n)u^{n+1} - f(u^n) = 0
> dt
> and solve
> (I - dt A(u^n))u^{n+1} = u^n + f(u^n).
> But for these to be reasonable approaches you need to know something about
> A() and f().
> I am making all these suggestions not because I think doing any of these
> things is reasonable, I'm just trying to guess at what you are trying to
> accomplish.
> Barry
> > Note that Picard
> > Solves the equation A(x) x = b(x) via the defect correction
> algorithm A(x^{n}) (x^{n+1} - x^{n}) = b(x^{n}) - A(x^{n})x^{n}
> > The functions you need to provide are (compute the vector) b(x) and
> (compute the matrix) A(x). A() is most definitely not the Jacobian of
> b(). To use Picard you have to rewrite the nonlinear equations that come
> out of the definition of the time-step in the form A(x) x = b(x). This may
> require additions to TS, I don't know.
> > Barry
> > > On Jan 1, 2017, at 8:56 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I tried using Picard inside of TS, and SNES diverged. Is this supposed
> to be possible? I tried to do do this by wrapping my operator in a SNES
> version and simply adding it like this.
> > > Mark
> > > ierr = TSSetIFunction(ts,NULL,LandIFunction,ctx);CHKERRQ(ierr);
> > > ierr = TSSetIJacobian(ts,J,J,LandIJacobian,ctx);CHKERRQ(ierr);
> > > SNES snes;
> > > Vec vec;
> > > ierr = VecDuplicate(uu,&vec);CHKERRQ(ierr);
> > > ierr = TSGetSNES(ts,&snes);CHKERRQ(ierr);
> > > ierr = SNESSetPicard(snes, vec, LandSNESFunction, J, J,
> LandSNESJacobian, ctx);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170103/ee1369f6/attachment.html>
