[petsc-dev] Scatter a single local value to multiple global values
Chris Eldred
chris.eldred at gmail.com
Wed Feb 22 11:04:05 CST 2017
Hey Jed,
That makes sense now, thanks! It sounds like the correct way to do things is:
For matrices:
1) for each set of coupled dofs, select 1 to be the master and modify
the local to global maps such that all the local indices that
previously pointed to the slave dofs now point to the master dof
-> assembly doesn't produce anything for the slave rows
2) fill the rows for the slave dofs with a -1 in the master column and
1 in the slave column (since we are just enforcing slave = master).
For residuals, just do 1) and then set slave dofs equal to the master dof.
The star forest write up is exactly what I was looking for, thanks!
Chris
On Wed, Feb 22, 2017 at 5:37 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Kong, Fande" <fande.kong at inl.gov> writes:
>> How about the inverse of SF? The original leaf becomes a new root, and the
>> original leaf will map to multiple new leafs?
> Chris has multiple local indices mapping to the same global index (this
> is the usual local-to-global map). He's eager to build a singular
> matrix and irritated that the tooling intentionally makes that harder to
> do by accident. ;-)
Chris Eldred
https://www.math.univ-paris13.fr/~eldred/
Postdoctoral Fellow, LAGA, University of Paris 13
PhD, Atmospheric Science, Colorado State University, 2015
DOE Computational Science Graduate Fellow (Alumni)
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
