[petsc-dev] Scatter a single local value to multiple global values
Jed Brown
jed at jedbrown.org
Wed Feb 22 10:37:51 CST 2017
"Kong, Fande" <fande.kong at inl.gov> writes:
> How about the inverse of SF? The original leaf becomes a new root, and the
> original leaf will map to multiple new leafs?
Chris has multiple local indices mapping to the same global index (this
is the usual local-to-global map). He's eager to build a singular
matrix and irritated that the tooling intentionally makes that harder to
do by accident. ;-)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170222/0ae7373a/attachment.sig>
