[petsc-dev] Compilation with ESSL SMP
Pierre Jolivet Pierre.Jolivet at enseeiht.fr
Tue Feb 21 09:15:32 CST 2017
On Mon, 20 Feb 2017 09:19:32 -0700, Jed Brown wrote:
> Pierre Jolivet <Pierre.Jolivet at enseeiht.fr> writes:
>> Hello,
>> It looks like the configure does not directly handle libesslsmpbg
> What did you pass to configure?  LIBS=-lesslsmpbg or similar?
Here are my options:
--known-sdot-returns-double=0 --known-snrm2-returns-double=0
--known-has-attribute-aligned=1 --CXXOPTFLAGS="-O3 -qnohot -qsimd=noauto
-qsmp=omp:noauto" --COPTFLAGS="-O3 -qnohot -qsimd=noauto
-qsmp=omp:noauto" --FOPTFLAGS="-O3 -qnohot -qsimd=noauto
-qsmp=omp:noauto" --prefix=build/complex --known-bits-per-byte=8
--known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32
--known-level1-dcache-size=32768 --known-memcmp-ok=1
--known-mpi-c-double-complex=1 --known-mpi-int64_t=1
--known-mpi-long-double=1 --known-mpi-shared-libraries=0
--known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4
--known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4
--known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8
--known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8
--with-batch
--with-blas-lapack-lib="[/bgsys/ibm_essl/prod/opt/ibmmath/essl/5.1/lib64/libesslsmpbg.a,/bglocal/cn/pub/LAPACK/3.7.0/lib/liblapack.a]"
--with-scalapack-lib="[/bglocal/cn/pub/ScaLAPACK/2.0.2/lib/libscalapack.a]"
--with-cc=mpixlc_r --with-clanguage=c --with-cpp="mpixlc_r -C -E"
--with-cxx=mpixlcxx_r --with-debugging=0 --with-endian=big
--with-fc=mpixlf90_r --with-fortran --with-make=gmake --with-mpi=yes
--with-scalar-type=complex --with-x=0
--download-sowing=../externalpackages/sowing-1.1.23-p1.tar.gz
--download-metis=../externalpackages/metis-5.1.0-p3.tar.gz
--download-mumps=../externalpackages/MUMPS_5.0.2.tar.gz
--download-parmetis=../externalpackages/parmetis-4.0.3-p3.tar.gz
--download-ptscotch=../externalpackages/scotch_6.0.4-p1.tar.gz
--download-pastix=../externalpackages/pastix_5.2.3.tar.bz2
PETSC_ARCH=arch-linux2-c-opt
But once the configure stage is complete, the following lib is printed:
BLAS/LAPACK: -lesslbg
Is it possible to force the use of libesslsmpbg? Do I need to force
that through the LIB argument as Jed suggested?
Thanks for all the input.
>> instead of libesslbg. On the other hand, it handles both
>> libmkl_intel_thread and libmkl_sequential.
>> Is there a reason for such a limitation? (I'd like to have direct
>> solvers linked with threaded BLAS).
> People do this by accident or without understanding the implications
> far
> more often than they do it intentionally.
