[petsc-dev] download problem p4est on Cori at NERSC
    Satish Balay
    balay at mcs.anl.gov
    Thu Feb 16 15:20:50 CST 2017
On Thu, 16 Feb 2017, Mark Adams wrote:
> > Satish, the tarballs for tagged commits that github generates are not
> > appropriate: here is a link to the tarball to be used in the event
> > that git is unavailable:
> > https://github.com/p4est/p4est.github.io/blob/master/
> > release/p4est-2.0.tar.gz
> Should I just grab this and put it in git.p4est?
https://bitbucket.org/petsc/petsc/commits/17b89b0c01d4afc6db39e4bf5d5b627c86379f16
I've pushed the tarball url fix to master. You can delete git.p4est - and rerun configure [on compute node?]
Satish
> > The "bootstrap" step is only called if `configure` isn't present,
> > which it should be in the tarball.
> > Cheers,
> >   Toby
> > > Satish
> > > On Wed, 15 Feb 2017, Mark Adams wrote:
> > > > Oh, this is because git does not work on KNL. Maybe I should do
> > > > with-batch=1,
> > > > On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > I get this error on the KNL partition at NERSC.  P4est works on the
> > > > > Haswell partition and other downloads seem to work on the KNL
> > partition.
> > > > > Any ideas?
