[petsc-dev] I don't understand PETSCPARTITIONSHELL
Matthew Knepley
knepley at gmail.com
Thu Feb 9 21:45:41 CST 2017
On Thu, Feb 9, 2017 at 9:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt,
> I don't understand PETSCPARTITIONSHELL.
> Why does it exist? Why not just use PETSCPARTITIONSIMPLE when no other
> partitioner exists?
> Why is it called shell? Other XXSHELL allow users to provide their own
> routines to provide the XX functionality, this does not seem to do that. So
> it is not shell in the PETSc sense.
> Why hard wire examples to use it? Why not just have list it as an args:
> in the test cases with -petscpartitioner_type shell (but why not just
> simple?) putting the ugly shit directly into the source code seems
> unnecessary and annoying.
1) The two partitioners do different things:
Simple: It divides the cells evenly without reordering.
Shell: It allows the user to set a prescribed partition
It is clear to me that Shell is needed because sometimes you want to
prescribe the partition, if for no
other reason than you know that a certain partition has a bug. Simple is
questionable, but we were
using it for testing.
2) It is called Shell because for a shell the user prescribes the behavior
directly, which is exactly what happens.
3) I did not put it in arguments because it can get very long, and I
thought it was easier to see and manipulate in the code. I am open to
moving it.
Matt
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/6cba58de/attachment.html>
