[petsc-dev] every test example runs in a new directory with new test harness
Thu Feb 9 16:32:20 CST 2017
On Mon, Feb 6, 2017 at 9:15 AM, Scott Kruger <kruger at txcorp.com> wrote:
> The basic idea of running multiple commands within a single shell
> script was what I called a subtest (for lack of a better word).
> So:
This almost works. However, the two tests create separate output, but the
text below checks both
runs against the same output. I tried using a "subsuffix", but it did not
change the output filename.
    Matt
>  test:
>     suffix: restart
>     requires: hdf5
>     args: -run_type test -refinement_limit 0.0    -bc_type dirichlet
> -interpolate 1 -petscspace_order 1
>     test:
>         args: -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append
>     test:
>         args: -f sol.h5 -restart
> The args in the subtest inherit from the parent test.  This seems
> to be generally useful as a testing idiom in petsc tests as this
> example nicely shows.
> Each mpiexec would be tested separately and reported separately.
> This would give you want you want, and should work as is.
> Tobin pointed out that I broke the for loops and some of the subtest
> functionality in some of the other feature implementations.  We
> have come to consensus (right, Tobin?) on the
> desired functionality and implementation.  A pull request
> is planned this week.  It doesn't affect this directly, but
> should have some minor improvements (like in the reporting).
> Scott
> On 2/6/17 7:10 AM, Matthew Knepley wrote:
>> On Mon, Feb 6, 2017 at 1:05 AM, Jed Brown <jed at jedbrown.org
>> <mailto:jed at jedbrown.org>> wrote:
>>     Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> writes:
>>     >   test:
>>     >     suffix: restart_0
>>     >     requires: hdf5
>> dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view
>> hdf5:sol.h5::append
>>     >   test:
>>     >     suffix: restart_1
>>     >     requires: hdf5
>> dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
>>     > See a problem?
>>     > Should the same run of the example view the files and then load
>> them back in? versus trying to read in a data file from another run that
>> may not even have been created before and even if it was, the file was
>> definitely created  in a different directory?
>>     So if write only is broken, do you want both to fail?  I think it's
>>     better to read and write separately, with comparison using h5diff,
>> since
>>     that independently tests read vs write and establishes backward
>>     compatibility, which you'd really like the test system to make you
>> deal
>>     with explicitly.
>> I know the test is broken, but I did already mail the list about this
>> and was waiting for an answer
>> to be worked out.
>> I agree with Satish that running two commands would be great. I could
>> rewrite the example to
>> both write and load it, but it would complicate it. Also, I am trying to
>> get the pattern I expect the
>> user to follow for checkpointing.
>>    Matt
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/8a02796b/attachment.html>
