[petsc-dev] every test example runs in a new directory with new test harness
    Scott Kruger
    kruger at txcorp.com
    Mon Feb  6 10:10:18 CST 2017
On 2/6/17 8:42 AM, Satish Balay wrote:
> I just tried it - and it doesn't appear to work..
I see.  The problem is with the argument inheritance.  I broke it when I
enabled command-line argument override.  The fix will be in the next
pull request this week
> Should the keyword for 'subtest' be different than 'test:'?
Jed's initial idea was to have it be truly
hierarchical although the parser currently only
supports one level.  Details of how to
do the inheritance gets confusing in practice.
Scott
> Satish
> balay at asterix /home/balay/petsc (next *=)
> $ git diff|cat
> diff --git a/src/snes/examples/tutorials/ex12.c b/src/snes/examples/tutorials/ex12.c
> index 71166bf..c097018 100644
> --- a/src/snes/examples/tutorials/ex12.c
> +++ b/src/snes/examples/tutorials/ex12.c
> @@ -1168,10 +1168,8 @@ int main(int argc, char **argv)
>      suffix: restart_0
>      requires: hdf5
>      args: -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append
> -  test:
> -    suffix: restart_1
> -    requires: hdf5
> -    args: -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
> +    test:
> +      args: -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
>    # Periodicity
>    test:
>      suffix: periodic_0
> $ ./config/gmakegentest.py
> $ cat arch-next/tests/src/snes/examples/tutorials/runex12_restart_0.sh
> #!/usr/bin/env bash
> # This script was created by gmakegentest.py
> # PATH for DLLs on windows
> PATH="$PATH":"/home/balay/petsc/arch-next/lib"
> mpiexec='mpiexec'
> exec='../ex12'
> testname='runex12_restart_0'
> label='snes_tutorials-ex12_restart_0'
> runfiles=''
> wPETSC_DIR='/home/balay/petsc'
> petsc_dir='/home/balay/petsc'
> args='-run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append'
> . "${petsc_dir}/config/petsc_harness.sh"
> # The diff flags come from script arguments
> diff_exe="${petsc_dir}/bin/petscdiff ${diff_flags}"
> printf "ok ${label} # SKIP PETSC_HAVE_HDF5 requirement not met\n"
> total=1; skip=1
> petsc_testend "/home/balay/petsc/arch-next/tests"
> exit
> petsc_testrun "${mpiexec} -n 1 ${exec} ${args}" ex12_restart_0.tmp ${testname}.err "${label}" ''
> petsc_testrun "${diff_exe} /home/balay/petsc/src/snes/examples/tutorials/output/ex12_restart_0.out ex12_restart_0.tmp" diff-${testname}.out diff-${testname}.out diff-${label} ""
> On Mon, 6 Feb 2017, Scott Kruger wrote:
>> The basic idea of running multiple commands within a single shell
>> script was what I called a subtest (for lack of a better word).
>> So:
>>  test:
>>     suffix: restart
>>     requires: hdf5
>>     test:
>>         args: -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append
>>     test:
>>         args: -f sol.h5 -restart
>> The args in the subtest inherit from the parent test.  This seems
>> to be generally useful as a testing idiom in petsc tests as this
>> example nicely shows.
>> Each mpiexec would be tested separately and reported separately.
>> This would give you want you want, and should work as is.
>> Tobin pointed out that I broke the for loops and some of the subtest
>> functionality in some of the other feature implementations.  We
>> have come to consensus (right, Tobin?) on the
>> desired functionality and implementation.  A pull request
>> is planned this week.  It doesn't affect this directly, but
>> should have some minor improvements (like in the reporting).
>> Scott
>> On 2/6/17 7:10 AM, Matthew Knepley wrote:
>>> On Mon, Feb 6, 2017 at 1:05 AM, Jed Brown <jed at jedbrown.org
>>> <mailto:jed at jedbrown.org>> wrote:
>>>     Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> writes:
>>>>   test:
>>>>     suffix: restart_0
>>>>     requires: hdf5
>>>>     hdf5:sol.h5::append
>>>>   test:
>>>>     suffix: restart_1
>>>>     requires: hdf5
>>>> See a problem?
>>>> Should the same run of the example view the files and then load them back
>>>> in? versus trying to read in a data file from another run that may not
>>>> even have been created before and even if it was, the file was definitely
>>>> created  in a different directory?
>>>     So if write only is broken, do you want both to fail?  I think it's
>>>     better to read and write separately, with comparison using h5diff, since
>>>     that independently tests read vs write and establishes backward
>>>     compatibility, which you'd really like the test system to make you deal
>>>     with explicitly.
>>> I know the test is broken, but I did already mail the list about this
>>> and was waiting for an answer
>>> to be worked out.
>>> I agree with Satish that running two commands would be great. I could
>>> rewrite the example to
>>> both write and load it, but it would complicate it. Also, I am trying to
>>> get the pattern I expect the
>>> user to follow for checkpointing.
>>>    Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
