[petsc-dev] using valgrind with new test harness
Satish Balay
balay at mcs.anl.gov
Wed Feb 8 16:47:08 CST 2017
Scott & Barry,
I'd like to remove the 'env' variable change. We don't want this to be
overwritten as it can be fragile [as users env can have incompatible
stuff here]
And petscmpiexec relies on env variables - so I'm not using it in the test harness.
So I have a branch scott/test-harness-valgrind-v2 (with commits collapsed/fixed)
So the following would be the way to use it.
make -f gmakefile test VALGRIND=1
Do you have any objections to this?
If we want them to be overwritted - then I guess we'll have to namespace them properly.
Satish
On Wed, 8 Feb 2017, Scott Kruger wrote:
> Actually Jed's discussion of using env for DIFF had me consider another
> solution than the one I had originally came up with. I have both mpiexec and
> diff using this new method to give what Barry
> wants more directly:
> https://bitbucket.org/petsc/petsc/pull-requests/631/
> Both of these now work at the makefile level:
> MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" make -e -f
> gmakefile test
> Note that I am passing the -e flag to make which has
> the environment variable override the value in
> ${PETSC_ARCH}/lib/conf/petscvariables
> This can be dangerous depending on how clean your environment is
> because it'll override ALL variables.
> And from the shell script level:
> runex1.sh -V
> MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" runex1.sh
> On 2/7/17 4:42 PM, Barry Smith wrote:
> > > On Feb 7, 2017, at 5:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > We cannot override stuff via env variables in the new test harness. For
> > > nightlybuilds
> > > I added support to check if PETSC_ARCH has 'valgrind' string in it - and
> > > if so - use
> > > valgrind.
> > > 26646c0bcc29652ef239540b066d00d1c8fc99c7
> > > Perhaps we can force this to use valgrind with:
> > > ./config/gmakegentest.py --valgrind=1
> > I can't decide at the time I run the tests, but need to decide when I do
> > the gmakegentest.py
> > > Ok - perhaps the attached patch.
> > That is one heck of a patch, talk about code duplication resulting in
> > endless bugs.
> > > But then - sometimes gmakefile runs ./config/gmakegentest.py directly
> > > [without valgrind]
> > Fix it properly somehow; currently it is impossible and that is insanely
> > horrible.
> > > Satish
> > > On Tue, 7 Feb 2017, Barry Smith wrote:
> > > > Both
> > > > make -f gmakefile test MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec
> > > > -valgrind "
> > > > and
> > > > MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind " make -f
> > > > gmakefile test
> > > > do not appear to use valgrind in the test harness (the old system did).
> > > > How do I run all tests under valgrind automatically?
> > > > not ok dm_impls_plex_tests-ex18_1
> > > > # [0]PETSC ERROR: PetscTrFreeDefault() called from
> > > > VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec\
> > > > /vec/impls/mpi/pdvec.c
> > > > # [0]PETSC ERROR: Block [id=0(32)] at address 0xb54240 is
> > > > # corrupted (probably write past end of array)
> > > > # [0]PETSC ERROR: Block allocated in VecCreate_MPI_Private() line
> > > > # 497 in /sandbox/bsmith/petsc/src/vec/vec/i\
> > > > mpls/mpi/pbvec.c
> > > > # [0]PETSC ERROR: --------------------- Error Message
> > > > # [0]PETSC ERROR: Memory corruption:
> > > > # http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
> > > > # [0]PETSC ERROR: Corrupted memory
> > > > # [0]PETSC ERROR: See
> > > > # http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> > > > # shooting.
> > > > # [0]PETSC ERROR: Petsc Development GIT revision:
> > > > # v3.7.5-3057-g2d11e0f GIT Date: 2017-02-07 15:39:04 -0600
> > > > # [0]PETSC ERROR: ../ex18 on a arch-single named es by bsmith Tue
> > > > # Feb 7 15:46:25 2017
> > > > # [0]PETSC ERROR: Configure options --download-ctetgen
> > > > # --download-exodusii --download-hdf5 --download-mpich \
> > > > --download-netcdf PETSC_ARCH=arch-single --with-precision=single
> > > > # [0]PETSC ERROR: #1 PetscTrFreeDefault() line 287 in
> > > > # /sandbox/bsmith/petsc/src/sys/memory/mtr.c
> > > > # [0]PETSC ERROR: #2 VecDestroy_MPI() line 18 in
> > > > # /sandbox/bsmith/petsc/src/vec/vec/impls/mpi/pdvec.c
> > > > # [0]PETSC ERROR: #3 VecDestroy() line 406 in
> > > > # /sandbox/bsmith/petsc/src/vec/vec/interface/vector.c
> > > > # [0]PETSC ERROR: #4 DMDestroy() line 681 in
> > > > # /sandbox/bsmith/petsc/src/dm/interface/dm.c
> > > > # [0]PETSC ERROR: #5 main() line 473 in
> > > > # /sandbox/bsmith/petsc/src/dm/impls/plex/examples/tests/ex18.c
> > > > # [0]PETSC ERROR: PETSc Option Table entries:
> > > > # [0]PETSC ERROR: -dm_view ascii::ascii_info_detail
> > > > # [0]PETSC ERROR: -interpolate
> > > <val.patch>
