[petsc-dev] using valgrind with new test harness
Scott Kruger
kruger at txcorp.com
Wed Feb 8 10:28:05 CST 2017
Actually Jed's discussion of using env for DIFF had me consider another
solution than the one I had originally came up with. I have both
mpiexec and diff using this new method to give what Barry
wants more directly:
https://bitbucket.org/petsc/petsc/pull-requests/631/
Both of these now work at the makefile level:
make -f gmakefile test VALGRIND=1
MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" make -e
-f gmakefile test
Note that I am passing the -e flag to make which has
the environment variable override the value in
${PETSC_ARCH}/lib/conf/petscvariables
This can be dangerous depending on how clean your environment is
because it'll override ALL variables.
And from the shell script level:
runex1.sh -V
MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" runex1.sh
On 2/7/17 4:42 PM, Barry Smith wrote:
>> On Feb 7, 2017, at 5:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> We cannot override stuff via env variables in the new test harness. For nightlybuilds
>> I added support to check if PETSC_ARCH has 'valgrind' string in it - and if so - use
>> valgrind.
>> 26646c0bcc29652ef239540b066d00d1c8fc99c7
>> Perhaps we can force this to use valgrind with:
>> ./config/gmakegentest.py --valgrind=1
> I can't decide at the time I run the tests, but need to decide when I do the gmakegentest.py
>> Ok - perhaps the attached patch.
> That is one heck of a patch, talk about code duplication resulting in endless bugs.
>> But then - sometimes gmakefile runs ./config/gmakegentest.py directly [without valgrind]
> Fix it properly somehow; currently it is impossible and that is insanely horrible.
>> Satish
>> On Tue, 7 Feb 2017, Barry Smith wrote:
>>> Both
>>> make -f gmakefile test MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind "
>>> and
>>> MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind " make -f gmakefile test
>>> do not appear to use valgrind in the test harness (the old system did).
>>> How do I run all tests under valgrind automatically?
>>> not ok dm_impls_plex_tests-ex18_1
>>> # [0]PETSC ERROR: PetscTrFreeDefault() called from VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec\
>>> /vec/impls/mpi/pdvec.c
>>> # [0]PETSC ERROR: Block [id=0(32)] at address 0xb54240 is corrupted (probably write past end of array)
>>> # [0]PETSC ERROR: Block allocated in VecCreate_MPI_Private() line 497 in /sandbox/bsmith/petsc/src/vec/vec/i\
>>> mpls/mpi/pbvec.c
>>> # [0]PETSC ERROR: --------------------- Error Message ------------------------------------------------------\
>>> # [0]PETSC ERROR: Memory corruption: http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>> # [0]PETSC ERROR: Corrupted memory
>>> # [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>> # [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3057-g2d11e0f GIT Date: 2017-02-07 15:39:04 -0600
>>> # [0]PETSC ERROR: ../ex18 on a arch-single named es by bsmith Tue Feb 7 15:46:25 2017
>>> # [0]PETSC ERROR: Configure options --download-ctetgen --download-exodusii --download-hdf5 --download-mpich \
>>> --download-netcdf PETSC_ARCH=arch-single --with-precision=single
>>> # [0]PETSC ERROR: #1 PetscTrFreeDefault() line 287 in /sandbox/bsmith/petsc/src/sys/memory/mtr.c
>>> # [0]PETSC ERROR: #2 VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec/vec/impls/mpi/pdvec.c
>>> # [0]PETSC ERROR: #3 VecDestroy() line 406 in /sandbox/bsmith/petsc/src/vec/vec/interface/vector.c
>>> # [0]PETSC ERROR: #4 DMDestroy() line 681 in /sandbox/bsmith/petsc/src/dm/interface/dm.c
>>> # [0]PETSC ERROR: #5 main() line 473 in /sandbox/bsmith/petsc/src/dm/impls/plex/examples/tests/ex18.c
>>> # [0]PETSC ERROR: PETSc Option Table entries:
>>> # [0]PETSC ERROR: -dm_view ascii::ascii_info_detail
>>> # [0]PETSC ERROR: -interpolate
>> <val.patch>
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
