[petsc-dev] using valgrind with new test harness
Barry Smith
bsmith at mcs.anl.gov
Tue Feb 7 17:04:35 CST 2017
Both
make -f gmakefile test MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind "
and
MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind " make -f gmakefile test
do not appear to use valgrind in the test harness (the old system did).
How do I run all tests under valgrind automatically?
not ok dm_impls_plex_tests-ex18_1
# [0]PETSC ERROR: PetscTrFreeDefault() called from VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec\
/vec/impls/mpi/pdvec.c
# [0]PETSC ERROR: Block [id=0(32)] at address 0xb54240 is corrupted (probably write past end of array)
# [0]PETSC ERROR: Block allocated in VecCreate_MPI_Private() line 497 in /sandbox/bsmith/petsc/src/vec/vec/i\
mpls/mpi/pbvec.c
# [0]PETSC ERROR: --------------------- Error Message ------------------------------------------------------\
# [0]PETSC ERROR: Memory corruption: http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
# [0]PETSC ERROR: Corrupted memory
# [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
# [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3057-g2d11e0f GIT Date: 2017-02-07 15:39:04 -0600
# [0]PETSC ERROR: ../ex18 on a arch-single named es by bsmith Tue Feb 7 15:46:25 2017
# [0]PETSC ERROR: Configure options --download-ctetgen --download-exodusii --download-hdf5 --download-mpich \
--download-netcdf PETSC_ARCH=arch-single --with-precision=single
# [0]PETSC ERROR: #1 PetscTrFreeDefault() line 287 in /sandbox/bsmith/petsc/src/sys/memory/mtr.c
# [0]PETSC ERROR: #2 VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec/vec/impls/mpi/pdvec.c
# [0]PETSC ERROR: #3 VecDestroy() line 406 in /sandbox/bsmith/petsc/src/vec/vec/interface/vector.c
# [0]PETSC ERROR: #4 DMDestroy() line 681 in /sandbox/bsmith/petsc/src/dm/interface/dm.c
# [0]PETSC ERROR: #5 main() line 473 in /sandbox/bsmith/petsc/src/dm/impls/plex/examples/tests/ex18.c
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -dm_view ascii::ascii_info_detail
# [0]PETSC ERROR: -interpolate
