[petsc-dev] plex test examples give different partitionings than output file even with simple partitioner? WTF
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 6 20:02:56 CST 2017
There appear to be several examples with "the wrong partitioning" in the output files? I think you need to list in the args: the partitioning you want otherwise it depends on what you currently have installed; which is worthless for regression tests.
See attached: all the different iteration counts are due to partitioning.
Barry
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170206/ff19feca/attachment.obj>
> On Feb 6, 2017, at 7:20 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 6, 2017 at 6:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt,
> How come? I check and it is using the simple partitioner and no random number generator is called. How come when I run it it gives a different partitioning than in the output file? The vectors also have different partitionings. Are the output files out of date?
> In my branch, ex15 has not had its partitioning replaced. It is still using ParMetis.
> I can do it.
> Matt
> ~/Src/petsc/src/dm/impls/plex/examples/tests (knepley/feature-plex-tests-new=) arch-double
> $ petscmpiexec -n 2 ./ex15 -verbose -globaltonatural_sf_view > joe
> $ paste output/ex15_0.out joe | more
> PetscSF Object: 2 MPI processes PetscSF Object: 2 MPI processes
> type not yet set type not yet set
> [0] Number of roots=6, leaves=6, remote ranks=1 [0] Number of roots=4, leaves=4, remote ranks=2
> [0] 0 <- (1,0) [0] 0 <- (0,0)
> [0] 1 <- (1,1) [0] 1 <- (0,1)
> [0] 2 <- (1,2) [0] 2 <- (1,0)
> [0] 3 <- (1,3) [0] 3 <- (1,1)
> [0] 4 <- (1,4) [1] Number of roots=14, leaves=14, remote ranks=2
> [0] 5 <- (1,5) [1] 0 <- (1,2)
> [1] Number of roots=12, leaves=12, remote ranks=2 [1] 1 <- (1,3)
> [1] 0 <- (1,6) [1] 2 <- (0,2)
> [1] 1 <- (1,7) [1] 3 <- (0,3)
> [1] 2 <- (1,8) [1] 4 <- (1,4)
> [1] 3 <- (1,9) [1] 5 <- (1,5)
> [1] 4 <- (0,0) [1] 6 <- (1,6)
> [1] 5 <- (0,1) [1] 7 <- (1,7)
> [1] 6 <- (1,10) [1] 8 <- (1,8)
> [1] 7 <- (1,11) [1] 9 <- (1,9)
> [1] 8 <- (0,2) [1] 10 <- (1,10)
> [1] 9 <- (0,3) [1] 11 <- (1,11)
> [1] 10 <- (0,4) [1] 12 <- (1,12)
> [1] 11 <- (0,5) [1] 13 <- (1,13)
> ==== original V in global ordering. size==18 block size=2 ==== original V in global ordering. size==18 block size=2
> Vec Object: V 2 MPI processes Vec Object: V 2 MPI processes
> type: mpi type: mpi
> Process [0] Process [0]
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
