[petsc-dev] partitioners that use bullshit random numbers
Matthew Knepley
knepley at gmail.com
Mon Feb 6 08:05:18 CST 2017
On Sun, Feb 5, 2017 at 9:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Is there any way we can substitute a deterministic random number
> generators for the bullshit partitioning packages that insist on using
> "system" non-portable random number generators? We should have tests that
> use metis/parmetis and chaco or whatever but we shouldn't have to deal with
> their bad decisions. Matt, what horrible partitioning is being used here?
I put in something that accepts fixed partitions, and it should be used for
all parallel tests. I converted a bunch of them already, but its
possible I missed this one.
The workflow for conversion is
a) Run the test with the -partition_view flag
b) The partition of cells prints out at the top
c) Copy that partition into a struct with the number of cells in one
array and the cells numbers in another. You can see an example in Plex
tests ex1.
d) Create a Shell Partitioner. Again refer to ex1
Matt
> Barry
> not ok diff-snes_tutorials-ex12_tri_bddc
> # 2,12c2,11
> # < 0 KSP Residual norm 11.5911
> # < 1 KSP Residual norm 0.419162
> # < 2 KSP Residual norm 0.0466633
> # < 3 KSP Residual norm 0.00282513
> # < 4 KSP Residual norm 0.000140711
> # < 5 KSP Residual norm 2.35332e-05
> # < 6 KSP Residual norm 8.28552e-07
> # < 7 KSP Residual norm 1.43643e-08
> # < 8 KSP Residual norm 2.827e-10
> # < Linear solve converged due to CONVERGED_RTOL iterations 8
> # < 1 SNES Function norm 7.836e-10
> # > 0 KSP Residual norm 11.6648
> # > 1 KSP Residual norm 0.443991
> # > 2 KSP Residual norm 0.0393777
> # > 3 KSP Residual norm 0.00187772
> # > 4 KSP Residual norm 0.000140435
> # > 5 KSP Residual norm 1.08843e-05
> # > 6 KSP Residual norm 2.87537e-07
> # > 7 KSP Residual norm 5.20043e-09
> # > Linear solve converged due to CONVERGED_RTOL iterations 7
> # > 1 SNES Function norm 1.59735e-08
> # 18c17
> # < total number of linear solver iterations=8
> # > total number of linear solver iterations=7
> # 76,77c75,76
> # < BDDC: Global dofs sizes: all 225 interface 43 coarse 7
> # < BDDC: Coarsening ratios: all/coarse 32 interface/coarse 6
> # > BDDC: Global dofs sizes: all 225 interface 57 coarse 9
> # > BDDC: Coarsening ratios: all/coarse 25 interface/coarse 6
> # 81,84c80,83
> # < BDDC: Interior dofs : 21 49 36
> # < BDDC: Interface dofs : 15 22 17
> # < BDDC: Primal dofs : 3 4 3
> # < BDDC: Local dofs : 36 64 54
> # > BDDC: Interior dofs : 21 42 33
> # > BDDC: Interface dofs : 15 36 23
> # > BDDC: Primal dofs : 3 6 4
> # > BDDC: Local dofs : 36 78 57
> # 99,100c98,99
> # < rows=7, cols=7
> # < total: nonzeros=35, allocated nonzeros=43
> # > rows=9, cols=9
> # > total: nonzeros=61, allocated nonzeros=68
> # 115c114
> # < factor fill ratio given 5., needed 1.17143
> # > factor fill ratio given 5., needed 1.13115
> # 119c118
> # < rows=7, cols=7
> # > rows=9, cols=9
> # 121c120
> # < total: nonzeros=41, allocated nonzeros=41
> # > total: nonzeros=69, allocated nonzeros=69
> # 127,128c126,127
> # < rows=7, cols=7
> # < total: nonzeros=35, allocated nonzeros=35
> # > rows=9, cols=9
> # > total: nonzeros=61, allocated nonzeros=61
> # 130c129
> # < not using I-node routines
> # > using I-node routines: found 7 nodes, limit
> used is 5
> # 135c134
> # < total: nonzeros=1585, allocated nonzeros=1764
> # > total: nonzeros=1625, allocated nonzeros=1855
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170206/4e2d847a/attachment.html>
