[petsc-dev] partitioners that use bullshit random numbers
Barry Smith
bsmith at mcs.anl.gov
Sun Feb 5 21:40:48 CST 2017
Is there any way we can substitute a deterministic random number generators for the bullshit partitioning packages that insist on using "system" non-portable random number generators? We should have tests that use metis/parmetis and chaco or whatever but we shouldn't have to deal with their bad decisions. Matt, what horrible partitioning is being used here?
Barry
not ok diff-snes_tutorials-ex12_tri_bddc
# 2,12c2,11
# < 0 KSP Residual norm 11.5911
# < 1 KSP Residual norm 0.419162
# < 2 KSP Residual norm 0.0466633
# < 3 KSP Residual norm 0.00282513
# < 4 KSP Residual norm 0.000140711
# < 5 KSP Residual norm 2.35332e-05
# < 6 KSP Residual norm 8.28552e-07
# < 7 KSP Residual norm 1.43643e-08
# < 8 KSP Residual norm 2.827e-10
# < Linear solve converged due to CONVERGED_RTOL iterations 8
# < 1 SNES Function norm 7.836e-10
# > 0 KSP Residual norm 11.6648
# > 1 KSP Residual norm 0.443991
# > 2 KSP Residual norm 0.0393777
# > 3 KSP Residual norm 0.00187772
# > 4 KSP Residual norm 0.000140435
# > 5 KSP Residual norm 1.08843e-05
# > 6 KSP Residual norm 2.87537e-07
# > 7 KSP Residual norm 5.20043e-09
# > Linear solve converged due to CONVERGED_RTOL iterations 7
# > 1 SNES Function norm 1.59735e-08
# 18c17
# < total number of linear solver iterations=8
# > total number of linear solver iterations=7
# 76,77c75,76
# < BDDC: Global dofs sizes: all 225 interface 43 coarse 7
# < BDDC: Coarsening ratios: all/coarse 32 interface/coarse 6
# > BDDC: Global dofs sizes: all 225 interface 57 coarse 9
# > BDDC: Coarsening ratios: all/coarse 25 interface/coarse 6
# 81,84c80,83
# < BDDC: Interior dofs : 21 49 36
# < BDDC: Interface dofs : 15 22 17
# < BDDC: Primal dofs : 3 4 3
# < BDDC: Local dofs : 36 64 54
# > BDDC: Interior dofs : 21 42 33
# > BDDC: Interface dofs : 15 36 23
# > BDDC: Primal dofs : 3 6 4
# > BDDC: Local dofs : 36 78 57
# 99,100c98,99
# < rows=7, cols=7
# < total: nonzeros=35, allocated nonzeros=43
# > rows=9, cols=9
# > total: nonzeros=61, allocated nonzeros=68
# 115c114
# < factor fill ratio given 5., needed 1.17143
# > factor fill ratio given 5., needed 1.13115
# 119c118
# < rows=7, cols=7
# > rows=9, cols=9
# 121c120
# < total: nonzeros=41, allocated nonzeros=41
# > total: nonzeros=69, allocated nonzeros=69
# 127,128c126,127
# < rows=7, cols=7
# < total: nonzeros=35, allocated nonzeros=35
# > rows=9, cols=9
# > total: nonzeros=61, allocated nonzeros=61
# 130c129
# < not using I-node routines
# > using I-node routines: found 7 nodes, limit used is 5
# 135c134
# < total: nonzeros=1585, allocated nonzeros=1764
# > total: nonzeros=1625, allocated nonzeros=1855
