[petsc-dev] IMPORTANT nightly builds are down do not add to next
    Jeff Hammond
    jeff.science at gmail.com
    Sat Dec 30 16:03:28 CST 2017
On Sat, Dec 30, 2017 at 12:04 PM Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >> On Dec 30, 2017, at 3:53 AM, Matthew Knepley <knepley at gmail.com> wrote:
> >> On Fri, Dec 29, 2017 at 5:35 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >> > On Dec 29, 2017, at 3:52 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> > On Fri, Dec 29, 2017 at 2:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >> >    The nightly builds are down (out-dated data at the website) and
> Satish is in India and cannot fix it.
> >> >     Please do not put anything into next until you are notified that
> the nightly tests are working again.
> >> > Cool.
> >> > This should tell us that we need to make more of an effort to
> automate this part, and employ failsafe measures.
> >>   Indeed. Note that this is largely just bad timing, this happens very
> rarely and it is just bad luck Satish is out.
> >> I agree completely. However, right now we are all too indispensible. We
> usually focus on transmitting developer knowledge,
> >> but I think we need more focus on transmitting process knowledge. Could
> another group of people pick up and run
> >> the maintenance process for PETSc?
> >    No because they would use jenkins or some similar worthless shit;
> >    we need to keep control of the processes but need more more help in
> >    running the processes.
> It shouldn't be this labor-intensive.  As I understand it, we could use
> free hosted CI except for proprietary compilers/unsupported
> environments.  Most of those CI systems want to sell their products with
> enterprise pricing for custom environments, but I think it's supposed to
> be easy to use the gitlab-ci runner on a custom machine.
You can use ICC and PGI in Travis CI, which is free if you use Github with
a public repo. ICC requires a friend at Intel to help with license issues.
PGI has community edition you should be able to use. Travis CI doesn’t
support Bitbucket but I recall you mirror Petsc there. Examples of both are
easily found with an obvious google search.
Travis CI is great for covering generic Mac/Homebrew and Ubuntu platforms.
You can get almost all compiler versions and MPI libraries in both, with
reasonable effort.
I can do an initial implementation if you aren’t inclined to do it
yourselves.
Jeff
> >    Basically another Satish, ideas on how to find such a person?
> Impossible to find "another Satish".
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171230/05f53a50/attachment.html>
