[petsc-dev] pnetcdf is a big problem
    Blaise A Bourdin
    bourdin at lsu.edu
    Wed Dec 20 11:14:32 CST 2017
There are two ways to write parallel netcdf files:
Use netcdf-4 (hdf5 based) files
Use pnetcdf and old-style netcdf files.
Perhaps the best would be to compile netcdf with pnetcdf support only if petsc is configured with exodusii? I can send a patch this afternoon.
Greg Sjaardema, the exodus maintainer, has been very responsive, I will try to iron out the last exodus / netcdf-4 bugs, but it sure would be noce to be able to read / write old style files too…
Blaise
> On Dec 19, 2017, at 5:32 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> On Dec 19, 2017, at 5:30 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Does ExodusII write pnetcdf?  It's a different interface from (parallel)
>> NetCDF4.
>   Shudder!
>> Matthew Knepley <knepley at gmail.com> writes:
>>> Blaise really wants to write in parallel. It would be better to use HDF5,
>>> but evidently
>>> it is broken in ExodusII. Thats what we get for using something from
>>> Sandia. They
>>> finally have their revenge.
>>>  Matt
>>> On Tue, Dec 19, 2017 at 5:53 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>> Do you really need to use pnetcdf? No one uses it and what usefulness
>>>> does it really provide, best to be avoided.
>>>>  Barry
>>>>> On Dec 19, 2017, at 1:12 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> parallel-netcdf-1.9.0.pre1/INSTALL has:
>>>>> 4. Reporting Installation or Usage Problems
>>>>> Please send an email to parallel-netcdf at mcs.anl.gov
>>>>> We'll have to send in these bug reports.
>>>>> Satish
>>>>> On Tue, 19 Dec 2017, Matthew Knepley wrote:
>>>>>> The configure is broken, perhaps beyond fixing. I need to give
>>>> --with-mpi
>>>>>> to get anything
>>>>>> to work because the way it checks for MPI is screwed up. I will see if I
>>>>>> can throw away all its idiotic configure stuff in favor of just telling
>>>> it
>>>>>> everything, but I am not eager to depend on something so rickety.
>>>>>> Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
