[petsc-dev] Efficient shifting vectors one position in array of vectors.
Wim Vanroose
wim at vanroo.se
Wed Aug 30 08:24:49 CDT 2017
Thanks! It works.
Wim
On Wed, Aug 30, 2017 at 3:21 PM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> sorry, forgot the last line of pointers swapping
> Vec tmp = Z_Vec[pipe_l];
> for(int i = pipe_l; i>0; i--){
> Z_Vec[i] = Z_Vec[i-1];
> Z_Vec[0] = tmp;
> 2017-08-30 16:19 GMT+03:00 Wim Vanroose <wim at vanroo.se>:
>> I've tried that in an earlier version. But it does not work. Then my
>> MatMult complains that
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: x and y must be different vectors
>> Because Vec[1] is then referring to Vec[0] where I am going to store the
>> result of the MatMult.
>> Also later on there are some AXPY that are complaining that that x and y
>> are the same vector.
>> Wim
>> On Wed, Aug 30, 2017 at 2:55 PM, Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> if you don't use KSPCreateVecs, but just a sequence of VecDuplicates,
>>> then you can swap pointers
>>> if you still want to use KSPCreateVecs, you need to keep track of what
>>> was the first vector of the sequence at the time of creation, because its
>>> address in memory points to the malloced memory for all the Vec pointers.
>>> 2017-08-30 15:45 GMT+03:00 Wim Vanroose <wim at vanroo.se>:
>>>> Dear Petsc Developers,
>>>> We are writing a pipelined CG with deep pipelines. For this
>>>> algorithm I need to
>>>> store "pipe_l +1" auxiliary variables Z_Vec. I create these
>>>> vectors as follows:
>>>> Vec *Z_VEC;
>>>> ierr = KSPCreateVecs(ksp,pipe_l+1,&Z_VEC,0,NULL);CHKERRQ(ierr);
>>>> Then we have a loop of iterations. However at some point I have to
>>>> drop the last
>>>> the auxiliary vector and shift the remaining vectors one position, and
>>>> replace the first vector with the result of a matvec.
>>>> This is in the current prototype implemented as
>>>> VecCopy( Z_VEC[i-1], Z_VEC[i] );
>>>> ierr = MatMult(A, Z_VEC[1], Z_VEC[0]);CHKERRQ(ierr);
>>>> It looks very inefficient to me to copy the vector, if we only want to
>>>> shift the data.
>>>> Do you have examples code where this is done more efficiently? Or is
>>>> this already a good way to do it?
>>>> Do you have suggestions?
>>>> Wim
>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170830/b18d8ea2/attachment-0001.html>
