[petsc-dev] Efficient shifting vectors one position in array of vectors.
    Stefano Zampini
    stefano.zampini at gmail.com
    Wed Aug 30 08:21:47 CDT 2017
sorry, forgot the last line of pointers swapping
Vec tmp = Z_Vec[pipe_l];
for(int i = pipe_l;  i>0; i--){
   Z_Vec[i] = Z_Vec[i-1];
Z_Vec[0] = tmp;
2017-08-30 16:19 GMT+03:00 Wim Vanroose <wim at vanroo.se>:
> I've tried that in an earlier version.  But it does not work. Then my
> MatMult complains that
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: x and y must be different vectors
> Because Vec[1] is then referring to  Vec[0] where I am going to store the
> result of the MatMult.
> Also later on there are some AXPY that are complaining that that x and y
> are the same vector.
> Wim
> On Wed, Aug 30, 2017 at 2:55 PM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
>> if you don't use KSPCreateVecs, but just a sequence of VecDuplicates,
>> then you can swap pointers
>> if you still want to use KSPCreateVecs, you need to keep track of what
>> was the first vector of the sequence at the time of creation, because its
>> address in memory points to the malloced memory for all the Vec pointers.
>> 2017-08-30 15:45 GMT+03:00 Wim Vanroose <wim at vanroo.se>:
>>> Dear Petsc Developers,
>>> We are writing a pipelined CG with deep pipelines.    For this algorithm
>>> I need to
>>> store   "pipe_l +1"  auxiliary variables  Z_Vec.    I create these
>>> vectors as follows:
>>>  Vec *Z_VEC;
>>>  ierr = KSPCreateVecs(ksp,pipe_l+1,&Z_VEC,0,NULL);CHKERRQ(ierr);
>>> Then we have a loop of iterations.   However at some point I have to
>>> drop the last
>>> the auxiliary vector and shift the remaining vectors one position, and
>>> replace the first vector with the result of a matvec.
>>> This is in the current prototype implemented as
>>>         VecCopy( Z_VEC[i-1], Z_VEC[i] );
>>>       ierr = MatMult(A, Z_VEC[1], Z_VEC[0]);CHKERRQ(ierr);
>>> It looks very inefficient to me to copy the vector, if we only want to
>>> shift the data.
>>> Do you have examples code where this is done more efficiently?  Or is
>>> this already a good way to do it?
>>> Do you have suggestions?
>>> Wim
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170830/19abe767/attachment.html>
