[petsc-dev] Bad tags
Satish Balay
balay at mcs.anl.gov
Sun Apr 23 13:33:14 CDT 2017
On Sun, 23 Apr 2017, Matthew Knepley wrote:
> On Sun, Apr 23, 2017 at 11:28 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > We went through this delete cycle a few times already - and they keep
> > coming back. Tags - once in wild - will never die :(
> > Hope bitbucket has a way to control the push of tags..
> > Matt,
> > Perhaps you still have some clones with 'push.followTags' enabled - and
> > they need to be fixed?
> > Note: - I think these tags came in through a PR
> I only have two clones. I just deleted tags in them. I am sure I did this
> before.
Matt - its primarily about the push.followTags config in your
~/.gitconfig or .git/config in your clones.
As far as I know - you are the only one with this config enabled.
Even if you delete tags in your repo - you might get them from other
repos, with a pull - and then they get pushed to bitbucket repo - due
the the above git configure that you have enabled.
Satish
> Thanks,
> Matt
> > Satish
> > On Sun, 23 Apr 2017, Lisandro Dalcin wrote:
> > > OK, at the risk of making a mistake, I deleted the tags for the remote
> > > repository to prevent escalation to everyone's repo.
> > > Please, all of you guys, do
> > > git fetch && git tag -d pre-tsfc archer-nonaffine
> > > On 23 April 2017 at 19:12, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > > > Satish, just did git pull, and new tags popped up. It seems someone
> > > > was using an old clone of the repo.
> > > > $ git pull
> > > > * [new tag] archer-nonaffine ->
> > > > archer-nonaffine
> > > > * [new tag] pre-tsfc ->
> > pre-tsfc
> > > > Lisandro Dalcin
> > > > Research Scientist
> > > > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > > > Extreme Computing Research Center (ECRC)
> > > > King Abdullah University of Science and Technology (KAUST)
> > > > http://ecrc.kaust.edu.sa/
> > > > 4700 King Abdullah University of Science and Technology
> > > > al-Khawarizmi Bldg (Bldg 1), Office # 0109
> > > > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > > > http://www.kaust.edu.sa
> > > > Office Phone: +966 12 808-0459
