[petsc-dev] WSL upgrade
Satish Balay
balay at mcs.anl.gov
Wed Apr 12 23:09:28 CDT 2017
On Wed, 12 Apr 2017, Jed Brown wrote:
> >> This is the error message that old blog post refers to
> >> https://blogs.msdn.microsoft.com/commandline/2016/10/19/interop-between-windows-and-bash/
> >> and the new post runs exactly the same command without error. Can you
> >> run "notepad.exe sizeof.c"?
> > I get the same error as the blog..
> The new one runs that exact command successfully. See
I'm on the new one. (version 1703, buid: 15063.138)
> Windows <-> Linux Interop
> https://blogs.msdn.microsoft.com/commandline/2017/04/11/windows-10-creators-update-whats-new-in-bashwsl-windows-console/
Notice the path (/mnt/c/temp) - its Windows FS - not WSL FS. That
works fine [as I mentioned earlier with my example usage]
Satish
> Something must be configured wrong.
