[petsc-dev] [petsc-users] FindPETSc.cmake expects petscvariables in wrong location
Satish Balay
balay at mcs.anl.gov
Tue Apr 11 11:13:27 CDT 2017
On Tue, 11 Apr 2017, Barry Smith wrote:
> > On Apr 11, 2017, at 10:43 AM, Joachim Wuttke <j.wuttke at fz-juelich.de> wrote:
> > The PETSc FAQ recommends to use the FindPETSc.cmake module
> Jed,
> Is it time to update the PETSc FAQ and remove the "recommendation"? I thought you had developed a simpler way of handling that does not require cmake?
Can I use CMake to build my own project that depends on PETSc?
Use the FindPETSc.cmake module from this repository. See the CMakeLists.txt from Dohp for example usage.
So its just a recommendation for cmake users?
For regular use - we recommend using petsc makefiles. [and once we
have a decent pkg-config infrastructure - we could swith to
recommending that..]
Satish
> Barry
> > from the repository https://github.com/jedbrown/cmake-modules.
> > This doesn't work for me. CMake fails with the following message:
> > CMake Error at cmake/modules/FindPETSc.cmake:125 (message):
> > The pair PETSC_DIR=/usr/lib/src/petsc-3.7.5 PETSC_ARCH=linux-amd64 do not
> > specify a valid PETSc installation
> > Line 115 of FindPETSc.cmake shows that the file petscvariables
> > is expected at location
> > ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/petscvariables
> > However, in the current source archive, it is located in
> > ${PETSC_DIR}/lib/petsc/conf/petscvariables,
> > and the default install procedure does not copy it to ${PETSC_ARCH}.
