[petsc-dev] problem with TSIRM in PETSc
Raphaël Couturier
raphael.couturier at univ-fcomte.fr
Mon Nov 14 10:53:54 CST 2016
This version is the correct version
https://bitbucket.org/petsc/petsc/history-node/1f2c6fc4275e/src/ksp/ksp/impls/tsirm/tsirm.c?at=master
The petsc-3.7.4.tar.gz is different. Line 68 there is a, for example:
ierr = PetscMalloc(tsirm->Iend-tsirm->Istart,&ind_row);CHKERRQ(ierr);
In the bitbucket version Line 64 it is
ierr = PetscMalloc1(tsirm->Iend-tsirm->Istart,&ind_row);CHKERRQ(ierr);
There are other differences
So we wonder whether it is normal or not.
Thank you
Raphaël
> And you an see the history of the tsirm.c file (in the master branch)
> on bitbucket, which might make that easier:
> On Mon, Nov 14, 2016 at 5:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Nov 14, 2016 at 2:29 AM, Raphaël Couturier
>> <raphael.couturier at univ-fcomte.fr> wrote:
>>> Hello all,
>>> We have submitted a code for TSIRM a new method to solve linear systems in
>>> PETSc, approximately one year ago, and we have a question. The code is
>>> different between the petsc version in bitbucket and in the last PETSc
>>> archive. In fact everything is working fine in the petsc version but not in
>>> the petsc-3.7.4. When we submitted the first version, it seemed that
>>> everything was fine for this part of the code. What could we do? Resubmit a
>>> new version? Wait the next PETSc release?
>> It would really help if you could give the SHA1 for the two versions you are
>> talking about.
>> Thanks,
>> Matt
>>> Thank you in advance for your answer.
>>> Raphaël
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161114/a302faa6/attachment.html>
