[petsc-dev] problem with TSIRM in PETSc
    Patrick Sanan
    patrick.sanan at gmail.com
    Mon Nov 14 10:36:35 CST 2016
And you an see the history of the tsirm.c file (in the master branch)
on bitbucket, which might make that easier:
https://bitbucket.org/petsc/petsc/history-node/1f2c6fc4275e/src/ksp/ksp/impls/tsirm/tsirm.c?at=master
On Mon, Nov 14, 2016 at 5:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 14, 2016 at 2:29 AM, Raphaël Couturier
> <raphael.couturier at univ-fcomte.fr> wrote:
>> Hello all,
>> We have submitted a code for TSIRM a new method to solve linear systems in
>> PETSc, approximately one year ago, and we have a question. The code is
>> different between the petsc version in bitbucket and in the last PETSc
>> archive. In fact everything is working fine in the petsc version but not in
>> the petsc-3.7.4. When we submitted the first version, it seemed that
>> everything was fine for this part of the code. What could we do? Resubmit a
>> new version? Wait the next PETSc release?
> It would really help if you could give the SHA1 for the two versions you are
> talking about.
>   Thanks,
>      Matt
>> Thank you in advance for your answer.
>> Raphaël
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
