[petsc-dev] mpi/cuda issue
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 22 13:17:16 CDT 2016
We can have next track the master of superlu_dist and then update the commit on master when the next is ok after a change to superlu_dist. If we track purely manually we will be months behind.
Barry
> On Mar 22, 2016, at 12:11 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 21 Mar 2016, Barry Smith wrote:
>>>>> On Mar 21, 2016, at 9:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> BTW: perils of using 'gitcommit=origin/master'
>>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/21/master.html
>>>>> Perhaps we should switch superlu_dist to use a working snapshot?
>>>>> self.gitcommit = '35c3b21630d93b3f8392a68e607467c247b5e053'
>>>>> balay at asterix /home/balay/petsc (master=)
>>>>> $ git grep origin/master config
>>>>> config/BuildSystem/config/packages/Chombo.py: self.gitcommit = 'origin/master'
>>>>> config/BuildSystem/config/packages/SuperLU_DIST.py: self.gitcommit = 'origin/master'
>>>>> config/BuildSystem/config/packages/amanzi.py: self.gitcommit = 'origin/master'
>>>>> config/BuildSystem/config/packages/saws.py: self.gitcommit = 'origin/master'
>>>> Satish and Hong,
>>>> Sherry has changed SuperLU_dist to have no name conflicts with SuperLU this means we need to update the SuperLU_dist interface for fix these problems. Once things have settled down we can use a release commit instead of master.
>>> Well the current issue is a breakage in superlu_dist build... [not the petsc interface]
>> Hmm, ok then we'll need to take a look at it.
> I think its best to keep petsc master stable [wrt superlu_dist] - so
> changed master to use 35c3b21630d93b3f8392a68e607467c247b5e053
> We should sync with superlu_dist manually [test in next - and then
> update master] - for any new changes..
> Satish
