[petsc-dev] mpi/cuda issue
Satish Balay
balay at mcs.anl.gov
Tue Mar 22 12:11:20 CDT 2016
On Mon, 21 Mar 2016, Barry Smith wrote:
> >>> On Mar 21, 2016, at 9:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> BTW: perils of using 'gitcommit=origin/master'
> >>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/21/master.html
> >>> Perhaps we should switch superlu_dist to use a working snapshot?
> >>> self.gitcommit = '35c3b21630d93b3f8392a68e607467c247b5e053'
> >>> balay at asterix /home/balay/petsc (master=)
> >>> $ git grep origin/master config
> >>> config/BuildSystem/config/packages/Chombo.py: self.gitcommit = 'origin/master'
> >>> config/BuildSystem/config/packages/SuperLU_DIST.py: self.gitcommit = 'origin/master'
> >>> config/BuildSystem/config/packages/amanzi.py: self.gitcommit = 'origin/master'
> >>> config/BuildSystem/config/packages/saws.py: self.gitcommit = 'origin/master'
> >> Satish and Hong,
> >> Sherry has changed SuperLU_dist to have no name conflicts with SuperLU this means we need to update the SuperLU_dist interface for fix these problems. Once things have settled down we can use a release commit instead of master.
> > Well the current issue is a breakage in superlu_dist build... [not the petsc interface]
> Hmm, ok then we'll need to take a look at it.
I think its best to keep petsc master stable [wrt superlu_dist] - so
changed master to use 35c3b21630d93b3f8392a68e607467c247b5e053
We should sync with superlu_dist manually [test in next - and then
update master] - for any new changes..
Satish
