[petsc-dev] Please make sure next is clean in nightly build before moving to master
Barry Smith
bsmith at mcs.anl.gov
Sun Mar 20 21:46:16 CDT 2016
Several branches have been merged to master recently that resulted in errors in the daily tests. After merging to next please make sure the nightly builds ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/index.html are clean in next before you merge to master; don't just assume that they were clean. And then the next day make sure that the master builds are clean. master has had several recently problems and this should rarely ever happen. Click on the [all] button on the upper right to make sure all examples are clean. You are not allowed to let any new diffs into master, including different iteration counts.
Thanks
Barry
