[petsc-dev] Problem in viewer for surface for 3D problem
Matthew Knepley
knepley at gmail.com
Thu Mar 17 09:50:47 CDT 2016
On Wed, Mar 16, 2016 at 7:23 AM, gouarin <loic.gouarin at math.u-psud.fr>
wrote:
> Hi,
> I try to use PETSc to solve BEM problem so I need to construct a surface
> with 3D coordinates. First of all, I would like to plot the mesh and I
> think that the output of the viewer is completely wrong.
> Here is a Python example
> import sys, petsc4py
> petsc4py.init(sys.argv)
> import numpy as np
> import petsc4py.PETSc as petsc
> coords = np.array([[0, 0, 0],
> [1, 0, 0],
> [0, 1, 0],
> [1, 1, 0],
> [0, 0, 1],
> [1, 0, 1],
> [0, 1, 1],
> [1, 1, 1],
> ], dtype=np.double)
> cells = np.array([[0, 1, 3, 2],
> [1, 5, 7, 3],
> [0, 4, 6, 2],
> [2, 3, 6, 7],
This quad is mis-specified, since 3-6 is a diagonal.
> [0, 1, 5, 4],
> [4, 5, 7, 6],
> ], dtype=np.int32)
> dm = petsc.DMPlex().createFromCellList(2, cells, coords,
> interpolate=False, comm=petsc.COMM_WORLD)
> viewer = petsc.Viewer().createHDF5('cube.h5', 'w')
> dm.view(viewer)
> If you look at the cells in the cube.h5, the numbering of the points is
> wrong.
I rewrote this in C, and I can visualize the surface. I then run it using
./ex18 -dm_view hdf5:dm.h5
and process that file
./bin/petsc_gen_xdmf.py dm.h5
This won't quite work when you have interpolate = PETSC_FALSE, because then
I do not force the 'viz' output,
however it can be forced with a viewer format.
Matt
> Thanks,
> Loic
> Loic Gouarin
> Laboratoire de Mathématiques
> Université Paris-Sud
> Bâtiment 425
> 91405 Orsay Cedex
> France
> Tel: (+33) 1 69 15 60 14
> Fax: (+33) 1 69 15 67 18
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160317/7c2a6315/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160317/7c2a6315/attachment.bin>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160317/7c2a6315/attachment.png>
