[petsc-dev] Problem in viewer for surface for 3D problem
gouarin
loic.gouarin at math.u-psud.fr
Wed Mar 16 07:23:54 CDT 2016
I try to use PETSc to solve BEM problem so I need to construct a surface
with 3D coordinates. First of all, I would like to plot the mesh and I
think that the output of the viewer is completely wrong.
Here is a Python example
import sys, petsc4py
petsc4py.init(sys.argv)
import numpy as np
import petsc4py.PETSc as petsc
coords = np.array([[0, 0, 0],
[1, 0, 0],
[0, 1, 0],
[1, 1, 0],
[0, 0, 1],
[1, 0, 1],
[0, 1, 1],
[1, 1, 1],
], dtype=np.double)
cells = np.array([[0, 1, 3, 2],
[1, 5, 7, 3],
[0, 4, 6, 2],
[2, 3, 6, 7],
[0, 1, 5, 4],
[4, 5, 7, 6],
], dtype=np.int32)
dm = petsc.DMPlex().createFromCellList(2, cells, coords,
interpolate=False, comm=petsc.COMM_WORLD)
viewer = petsc.Viewer().createHDF5('cube.h5', 'w')
dm.view(viewer)
If you look at the cells in the cube.h5, the numbering of the points is
wrong.
Loic
Loic Gouarin
Laboratoire de Mathématiques
Université Paris-Sud
Bâtiment 425
91405 Orsay Cedex
France
Tel: (+33) 1 69 15 60 14
Fax: (+33) 1 69 15 67 18
