[petsc-dev] Fwd: PETSc blame digest (next) 2016-03-15
Karl Rupp rupp at iue.tuwien.ac.at
Tue Mar 15 16:30:36 CDT 2016
Hi Satish,
On 03/15/2016 04:59 PM, Satish Balay wrote:
> How about:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/15/filtered-make_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log
> /usr/home/balay/petsc.clone-3/src/vec/vec/utils/ftn-auto/vscatf.c: In function 'void vecscatterinitializeforgpu_(VecScatter, Vec, ScatterMode*, int*)':
> /usr/home/balay/petsc.clone-3/src/vec/vec/utils/ftn-auto/vscatf.c:100:33: error: 'VecScatterInitializeForGPU' was not declared in this scope
>    (Vec)PetscToPointer((x) ),*mode);
> For one - there is some inconsistancy in the definition of this function wrt interface vs impl.
> I'm not sure what our policy here is . Always have this function
> available in public API - or selectively have it enabled? Either way -
> it should be consistant across sources (include, c-interface, fortran-interface).
I disabled the Fortran interface and fixed the function signature
mismatch here:
https://bitbucket.org/petsc/petsc/commits/a614883e62f797ac619ffc772442ec50b9faedf0
Since the routine is only used for multi-GPU MatMult, not exposing a
Fortran interface is not a problem. Thus, it's enough to just properly
guard the functions with #if defined(...)
Thanks and best regards,
Karli
