[petsc-dev] valgrind question
Xiaoye S. Li xsli at lbl.gov
Wed Mar 2 17:36:30 CST 2016
Yes, I already removed the ones that you mentioned several weeks ago.
It's good now that I have this good setup on my own Linux box; before I
have been using exclusively on NERSC machine. Running valgrind in Cray
environment gives huge number of warnings, pretty much useless.
Sherry
On Wed, Mar 2, 2016 at 3:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 2, 2016, at 4:22 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > I didn't do that. I will re-configure MPICH.
> > But, the superlu_dist_valgrind_errors file you sent me a few days ago
> also contains this kind of errors.
>   You are right. I apologize, for the tests we run now we do not see any
> valgrind errors inside SuperLU_Dist. Looks like you have eliminated all of
> the ones we use to see with your previous set of fixes.
>    Barry
> > Sherry
> > On Wed, Mar 2, 2016 at 2:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    When you configured MPICH did you use the flag --enable-g=meminit so
> it would not generate its own valgrind errors?
> >   Barry
> > > On Mar 2, 2016, at 4:11 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > > I check that file, it also show not stripped. Not sure why it doesn't
> work.  Now I am using static library build to run valgrind, which works
> fine.
> > > Now on to the valgrind output, I see quite a few warnings are
> unnecessary. For example,
> > > ==13292== Conditional jump or move depends on uninitialised value(s)
> > > ==13292==    at 0x5452D86: MPIC_Waitall (in
> /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > > ==13292==    by 0x53AB23F: MPIR_Alltoall_intra (in
> > > ==13292==    by 0x53ABFD4: MPIR_Alltoall (in
> > > ==13292==    by 0x53AC08D: MPIR_Alltoall_impl (in
> > > ==13292==    by 0x53AC896: PMPI_Alltoall (in
> > > ==13292==    by 0x418161: dReDistribute_A (pddistribute.c:108)
> > > ==13292==    by 0x41950B: pddistribute (pddistribute.c:450)
> > > ==13292==    by 0x407D6A: pdgssvx (pdgssvx.c:1080)
> > > ==13292==    by 0x4027E5: main (pddrive.c:171)
> > > The line in pddistribute.c: 108 is this:
> > >     MPI_Alltoall( nnzToSend, 1, mpi_int_t, nnzToRecv, 1, mpi_int_t,
> > >           grid->comm);
> > > For both buffers nnzToSend and nnzToRecv, I use "calloc" version to
> allocate memory, i.e., malloc first, followed by zeroing the buffer.
> > > mpi_int_t is defined as MPI_INT.
> > > Why does it complain about uninitialized values?
> > > Sherry
> > > On Tue, Mar 1, 2016 at 8:27 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > sometimes 'cmake' does a 'strip' during install of the library [which
> > > can delete the debug symbols]. We had to track this down for one of
> > > the cmake packages. I don't remember what we did to workarround it..
> > > petsc at es:/scratch/petsc/petsc/arch-linux-pkgs-valgrind/lib$ file
> libsuperlu_dist.so.5.0.0
> > > libsuperlu_dist.so.5.0.0: ELF 64-bit LSB shared object, x86-64,
> version 1 (SYSV), dynamically linked, not stripped
> > > looks like superlu_dist installed by petsc is not stripped. Perhaps
> > > you can try:
> > > file
> /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsuperlu_dist.so.5.0.0
> > > Satish
> > > On Tue, 1 Mar 2016, Barry Smith wrote:
> > > >   Satish will know far better than me. I only use Linux when my Mac
> OS fails me :-(
> > > > > On Mar 1, 2016, at 8:41 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > > > > This is on linux (ubunto).  I did compile with -g, but only the
> example driver (which is outside library) shows the line number, the
> routine in the *.so does not show line number, see this:
> > > > > ==31609== Conditional jump or move depends on uninitialised
> value(s)
> > > > > ==31609==    at 0x51EED86: MPIC_Waitall (in
> > > > > ==31609==    by 0x5148F99: MPIR_Alltoallv_intra (in
> > > > > ==31609==    by 0x5149916: MPIR_Alltoallv (in
> > > > > ==31609==    by 0x51499F6: MPIR_Alltoallv_impl (in
> > > > > ==31609==    by 0x514A0C7: PMPI_Alltoallv (in
> > > > > ==31609==    by 0x4E7C56A: pdCompRow_loc_to_CompCol_global (in
> /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsupe\
> > > > > rlu_dist.so.5.0.0)
> > > > > ==31609==    by 0x4E71761: pdgssvx (in
> /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsuperlu_dist.so.5.0.0)
> > > > > ==31609==    by 0x401400: main (pddrive.c:171)
> > > > > Here are the flags:
> > > > > C_FLAGS =  -DUSE_VENDOR_BLAS -DAdd_ -DDEBUGlevel=0 -DPRNTlevel=0
> -std=c99 -g -fPIC -I/home/xiaoye/Dropbox/Codes/SuperLU/superl\
> > > > > u_dist.git/SRC -I/home/xiaoye/lib/parmetis-4.0.3/include
> -I/home/xiaoye/lib/parmetis-4.0.3/metis/include -I/home/xiaoye/mpich-\
> > > > > install/include
> > > > > Any idea?
> > > > > Sherry
> > > > > On Tue, Mar 1, 2016 at 6:00 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > > > On Mar 1, 2016, at 7:41 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > > > > > Barry,
> > > > > > I am cleaning up the valgrind errors. I did a build with shared
> library option, but valgrind doesn't give me the source code line number.
> Is it true that I need to build as static library?
> > > > >   No but if you are running on an Apple you may need the
> additional valgrind option --dsymutil=yes  (yes it is totally goofy that it
> doesn't just do this automatically). Also, of course, the source code needs
> be compiled with the -g option.
> > > > >   Barry
> > > > > > Sherry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160302/a30a4176/attachment.html>
