[petsc-dev] [petsc-checkbuilds at mcs.anl.gov: PETSc blame digest (next) 2016-03-02]
Patrick Sanan patrick.sanan at gmail.com
Wed Mar 2 09:49:30 CST 2016
I'm not sure how to silence this (demangled) warning from the nightlies:
"/export/home/petsc/petsc.clone-3/src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c", line 112: warning: statement not reached
There are a few other warnings of the same form in the log linked below, on the first source line
after something like
#ifdef PETSC_USE_COMPLEX
#endif
or in the case of the particular warning here, the first source line (after some other preprocessor directives) after
#if (defined(PETSC_USE_COMPLEX) && !defined(PETSC_SKIP_COMPLEX))
  SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_SUP,"PIPEFGMRES has not been implemented for use with complex scalars");
#endif
----- Forwarded message from PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> -----
From: PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
To: Patrick Sanan <patrick.sanan at gmail.com>, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
Date: Wed,  2 Mar 2016 09:00:08 -0600 (CST)
Subject: PETSc blame digest (next) 2016-03-02
Dear PETSc developer,
This email contains listings of contributions attributed to you by
`git blame` that caused compiler errors or warnings in PETSc automated
testing.  Follow the links to see the full log files. Please attempt to fix
the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
to resolve the issues.
  The PETSc development team
warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/390d8e4
KSP: Add KSPPIPEFCG
  src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c:112
    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/02/build_next_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log]
      "/export/home/petsc/petsc.clone-3/src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c", line 112: warning:           CC arch-opensolaris-cmplx-pkgs-dbg/obj/src/ksp/ksp/impls/symmlq/symmlq.o
To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
----- End forwarded message -----
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160302/5a2a9fea/attachment.sig>
