[petsc-dev] [petsc-checkbuilds at mcs.anl.gov: PETSc blame digest (next) 2016-03-02]
Wed Mar 2 11:46:53 CST 2016
Yeah - parallel builds have this issue. GNUMake4+ has an option
'--output-sync=recurse' that we use to aovid this munging of output.
But some of the builds don't use gnumake [or have older versions of
gnumake] - and this option misbehaves on some machines [freebsd/osx] -
so some these builds will continue to have this issue.
Satish
On Wed, 2 Mar 2016, Patrick Sanan wrote:
> Ah, I see - it probably got sent to me exactly because the output was mangled, so the actual error message wasn't there.
> On Wed, Mar 02, 2016 at 11:31:14AM -0600, Barry Smith wrote:
> >    Don't worry about it. We try to filter out that particular warning from the tests but sometimes it gets picked up and reported.
> >    Barry
> > > On Mar 2, 2016, at 9:49 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> > > I'm not sure how to silence this (demangled) warning from the nightlies:
> > > "/export/home/petsc/petsc.clone-3/src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c", line 112: warning: statement not reached
> > > There are a few other warnings of the same form in the log linked below, on the first source line
> > > after something like
> > > #ifdef PETSC_USE_COMPLEX
> > > #endif
> > > or in the case of the particular warning here, the first source line (after some other preprocessor directives) after
> > > #if (defined(PETSC_USE_COMPLEX) && !defined(PETSC_SKIP_COMPLEX))
> > >  SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_SUP,"PIPEFGMRES has not been implemented for use with complex scalars");
> > > #endif
> > > ----- Forwarded message from PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> -----
> > > From: PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
> > > To: Patrick Sanan <patrick.sanan at gmail.com>, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
> > > Date: Wed,  2 Mar 2016 09:00:08 -0600 (CST)
> > > Subject: PETSc blame digest (next) 2016-03-02
> > > Dear PETSc developer,
> > > This email contains listings of contributions attributed to you by
> > > `git blame` that caused compiler errors or warnings in PETSc automated
> > > testing.  Follow the links to see the full log files. Please attempt to fix
> > > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > > to resolve the issues.
> > > Thanks,
> > >  The PETSc development team
> > > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/390d8e4
> > > KSP: Add KSPPIPEFCG
> > >  src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c:112
> > >    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/02/build_next_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log]
> > >      "/export/home/petsc/petsc.clone-3/src/ksp/ksp/impls/fcg/pipefcg/pipefcg.c", line 112: warning:           CC arch-opensolaris-cmplx-pkgs-dbg/obj/src/ksp/ksp/impls/symmlq/symmlq.o
> > > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
> > > ----- End forwarded message -----
