[petsc-dev] Question about DMCreateDomainDecomposition()
Lawrence Mitchell
lawrence.mitchell at imperial.ac.uk
Mon Jul 18 10:06:00 CDT 2016
On 18/07/16 15:49, Lulu Liu wrote:
> Hi,
> I add the following lines in the example
> /petsc/src/snes/examples/tutorials/ex19. When I run this example using
> different numbers of processors, n always equals to 1. However,
> according to the manual, n is the number of subproblems in the domain
> decomposition. I feel confused why n does not return the number of
> processors, could you explain it? Thanks!
> PetscInt n;
> DM *subdms;
> ierr
> =DMCreateDomainDecomposition(da,&n,NULL,NULL,NULL,&subdms);CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_WORLD,"### n==%d\n", n);
You need to do -da_local_subdomains nsubdomain_per_process
or else call DMDASetNumLocalSubdomains
Cheers,
Lawrence
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160718/2bf1c9bc/attachment.sig>
