[petsc-dev] p4est configure error
    Tobin Isaac
    tisaac at uchicago.edu
    Thu Jul  7 09:26:26 CDT 2016
On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> p4est on Edison configures in w/o debugging, although I have to run
> configure twice.
> But with debugging it fails.  I can not see any difference between the two
> configures other than debugging.
> Mark
The log shows that you are configuring a p4est commit (3d3e1) that is
before the one I pushed specifically to avoid the fortran
configuration error (f54bb3).  Please clear the git.p4est directory,
and confirm that you are configuring with the current 'petsc' branch
of p4est (`grep 'checking Point version' configure.log` should show
X.XXX-a9f22).
Cheers,
  Toby
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/c8d02ea0/attachment.sig>
