[petsc-dev] pets error Segmentation Violation
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Jul  1 14:35:56 CDT 2016
  No idea. You need to do what it says and run with valgrind or in a debugger. From the crash message it looks like it is crashing in your main program.
   Barry
> On Jul 1, 2016, at 1:26 PM, 张江 <zhangjiang.dudu at gmail.com> wrote:
> Hi,
> I am trying to read a large data (11.7GB) with libmesh (integrated with PETSc) and use it for my application. The program runs well when using just one process. But in parallel (mpirun -n 4), some errors came out:
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> [0]PETSC ERROR: ./ptracer on a arch-linux2-c-debug named compute001 by jiangzhang Fri Jul  1 10:07:07 2016
> [0]PETSC ERROR: Configure options --prefix=/nfs/proj-tpeterka/jiang/opt/petsc-3.7.2 --download-fblaslapack --with-mpi-dir=/nfs/proj-tpeterka/jiang/libraries/mpich-3.2
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> Anybody know the possible causes?
