[petsc-dev] [petsc-users] PETSc release soon, request for input on needed fixes or enhancements
Griffith, Boyce Eugene
boyceg at email.unc.edu
Mon Feb 29 10:39:20 CST 2016
> On Feb 29, 2016, at 12:15 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 27, 2016, at 8:22 PM, Boyce Griffith <griffith at cims.nyu.edu> wrote:
>> Barry —
>> I haven’t been following master, and so maybe these have already been addressed, but is there a chance that fixes for the performance issues Amneet found (options in setting up lots of KSPs in small-block ASM,
> Thanks for the reminder. I have added a new ./configure option --with-viewfromoptions=0 which will remove all of that overhead and likely perform better than the "hack" I suggested to apply earlier. This is in the branch barry/fixes-for-release-1 and will be in master if it passes all the test.
> I'll also remind you of the option --with-errorchecking=0 which turns off additional overhead that in theory is not needed in production runs and could help a bit more when using many small solvers.
Thanks Barry! Is --with-errorchecking=0 implied by --with-debugging=0 (or vice versa), or are these somewhat independent? We were running the timing tests with --with-debugging=0 but not with --with-errorchecking=0.
Amneet, can you please verify that the performance issues you uncovered are fixed with a clean checkout of the PETSc branch Barry mentions above along with the foregoing PETSc configure options?
-- Boyce
> Please let us know if there are any difficulties.
> Barry
>> and logging of IS objects) will make it into 3.7?
>> Thanks,
>> — Boyce
>>> On Feb 27, 2016, at 3:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> PETSc Users,
>>> We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
>>> You can think of the master branch of the PETSc repository obtainable with
>>> git clone https://bitbucket.org/petsc/petsc petsc
>>> as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>>> Thanks
>>> Barry
