[petsc-dev] [petsc-users] PETSc release soon,	request for input on needed fixes or enhancements
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Feb 28 23:15:06 CST 2016
> On Feb 27, 2016, at 8:22 PM, Boyce Griffith <griffith at cims.nyu.edu> wrote:
> Barry —
> I haven’t been following master, and so maybe these have already been addressed, but is there a chance that fixes for the performance issues Amneet found (options in setting up lots of KSPs in small-block ASM,
   Thanks for the reminder. I have added a new ./configure option --with-viewfromoptions=0 which will remove all of that overhead and likely perform better than the "hack" I suggested to apply earlier. This is in the branch barry/fixes-for-release-1 and will be in master if it passes all the test.
   I'll also remind you of the option --with-errorchecking=0 which turns off additional overhead that in theory is not needed in production runs and could help a bit more when using many small solvers.
  Please let us know if there are any difficulties.
  Barry
> and logging of IS objects) will make it into 3.7?
> Thanks,
> — Boyce
>> On Feb 27, 2016, at 3:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  PETSc Users,
>>   We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
>>   You can think of the master branch of the PETSc repository obtainable with
>> git clone https://bitbucket.org/petsc/petsc petsc
>> as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>>  Thanks
>>  Barry
