[petsc-dev] Installation namespaces
Jed Brown
jed at jedbrown.org
Sun Dec 25 18:43:35 CST 2016
Almost nothing we install to $prefix/bin is namespaced, let alone
required to use PETSc. I think we should remove most of it from prefix
installs and namespace everything that is truly needed.
And we really need to stop installing the ridiculous bin/*
subdirectories (especially bin/maint). Nobody uses directories in /bin
and most of the stuff in bin/maint is not relevant to prefix installs.
Most of those directories should either be not installed or go in
lib/petsc/.
I also have a complaint about stale install trees. I had an old
PETSC_ARCH (built long ago). I updated my repository to today's
'master' and did
make reconfigure gnumake install
and it installed (to a just-cleaned prefix):
petsc-mpich-basic-prefix/lib/modules
petsc-mpich-basic-prefix/lib/modules/3.4.2
petsc-mpich-basic-prefix/lib/modules/3.4.3
I believe this is because we copy all of PETSC_ARCH/lib (those files
existed a couple years ago when this arch was first built). I consider
this to be a bug, though it feels hard to fix in the current
environment. I think it would be better to move our installs to a
whitelist scheme (perhaps with globbing) rather than bulk copy.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161225/1f66f61c/attachment.sig>
