[petsc-dev] Correct syntax for DMDA ownership ranges in petsc4py
Chris Eldred chris.eldred at gmail.com
Fri Apr 8 02:29:56 CDT 2016
Hey Matt,
Yes I have tried all possible variants:
[(8,8,4),]
([8,8,4],)
[[8,8,4],]
((8,8,4),)
and they all fail with the same
TypeError: Expected tuple, got list
However, I think I see what is happening now. In line 156
    cdef object ranges = list(ownership_ranges)
it looks like ranges is being defined as a list, rather than a tuple.
So maybe there should be a cast from list to tuple in the return
statement?
-Chris
On Thu, Apr 7, 2016 at 9:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Apr 7, 2016 at 2:14 PM, Chris Eldred <chris.eldred at gmail.com> wrote:
>> I think what happens on the 1st version is that the input list has
>> len(3), and since the DMDA only has 1 dimension petsc4py throws the
>> first ValueError.
> Yes, you are right.
>> As far as I can tell, the code is expecting a list of lists: ie for
>> each dimension it gets ranges[i] (where i is the index for the
>> dimension) and casts it into an array. So I tried the 2nd version,
>> which fails regardless of whether I use lists or tuples, and I don't
>> understand why.
> That function returns 'range' and the type is declared as tuple. Did you try
>   ownership_ranges=((8,8,4),)
>     Matt
>> -Chris
>> On Thu, Apr 7, 2016 at 9:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Thu, Apr 7, 2016 at 1:52 PM, Chris Eldred <chris.eldred at gmail.com>
>> > wrote:
>> >> Hey All,
>> >> (I sent this to petsc-users a few days ago and didn't get any replies,
>> >> figured I would try here as well...)
>> >> Does anyone know the correct syntax for setting ownership ranges for
>> >> DMDAs in petsc4py? For example, if I have a 1D DMDA with 20 vertices
>> >> and 3 processes, and I want to distribute the vertices as [8,8,4],
>> >> should the correct create call be:
>> >> da =
>> >> PETSc.DMDA().create(dim=1,dof=1,sizes=[20,],proc_sizes=[3,],boundary_type=[PETSc.DM.BoundaryType.PERIODIC,],
>> >> stencil_type= PETSc.DMDA.StencilType.BOX,
>> >> stencil_width=1,ownership_ranges=[8,8,4])
>> >> or
>> >> da =
>> >> stencil_width=1,ownership_ranges=[[8,8,4],])
>> >> For me, the 1st version fails with
>> >> ValueError: number of dimensions 1 and number ownership ranges 3
>> >> (which I expected)
>> >> but the 2nd version also fails with
>> >> I have tried using tuples instead of lists and nothing changes.
>> >> Creating without the ownership_ranges argument works fine as well. Is
>> >> there something else I am missing?
>> > Here is the code:
>> > https://bitbucket.org/petsc/petsc4py/src/b234a50085607b793fce93d5dc46307c0d9b57c4/src/PETSc/petscdmda.pxi?at=master&fileviewer=file-view-default#petscdmda.pxi-150
>> > I do not understand why the 1st version fails.
>> >    Matt
>> >> Thanks in advance for any assistance!
>> >> Regards,
>> >> -Chris
>> >> Chris Eldred
>> >> Postdoctoral Fellow, LAGA, University of Paris 13
>> >> PhD, Atmospheric Science, Colorado State University, 2015
>> >> DOE Computational Science Graduate Fellow (Alumni)
>> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
>> > What most experimenters take for granted before they begin their
>> > experiments
>> > is infinitely more interesting than any results to which their
>> > experiments
>> > lead.
>> > -- Norbert Wiener
>> Chris Eldred
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Chris Eldred
