[petsc-dev] Correct syntax for DMDA ownership ranges in petsc4py
Matthew Knepley
knepley at gmail.com
Thu Apr 7 14:19:35 CDT 2016
On Thu, Apr 7, 2016 at 2:14 PM, Chris Eldred <chris.eldred at gmail.com> wrote:
> I think what happens on the 1st version is that the input list has
> len(3), and since the DMDA only has 1 dimension petsc4py throws the
> first ValueError.
Yes, you are right.
> As far as I can tell, the code is expecting a list of lists: ie for
> each dimension it gets ranges[i] (where i is the index for the
> dimension) and casts it into an array. So I tried the 2nd version,
> which fails regardless of whether I use lists or tuples, and I don't
> understand why.
That function returns 'range' and the type is declared as tuple. Did you try
ownership_ranges=((8,8,4),)
Matt
> -Chris
> On Thu, Apr 7, 2016 at 9:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Apr 7, 2016 at 1:52 PM, Chris Eldred <chris.eldred at gmail.com>
> wrote:
> >> Hey All,
> >> (I sent this to petsc-users a few days ago and didn't get any replies,
> >> figured I would try here as well...)
> >> Does anyone know the correct syntax for setting ownership ranges for
> >> DMDAs in petsc4py? For example, if I have a 1D DMDA with 20 vertices
> >> and 3 processes, and I want to distribute the vertices as [8,8,4],
> >> should the correct create call be:
> >> da =
> PETSc.DMDA().create(dim=1,dof=1,sizes=[20,],proc_sizes=[3,],boundary_type=[PETSc.DM.BoundaryType.PERIODIC,],
> >> stencil_type= PETSc.DMDA.StencilType.BOX,
> >> stencil_width=1,ownership_ranges=[8,8,4])
> >> or
> >> da =
> >> stencil_width=1,ownership_ranges=[[8,8,4],])
> >> For me, the 1st version fails with
> >> ValueError: number of dimensions 1 and number ownership ranges 3
> >> (which I expected)
> >> but the 2nd version also fails with
> >> TypeError: Expected tuple, got list
> >> I have tried using tuples instead of lists and nothing changes.
> >> Creating without the ownership_ranges argument works fine as well. Is
> >> there something else I am missing?
> > Here is the code:
> https://bitbucket.org/petsc/petsc4py/src/b234a50085607b793fce93d5dc46307c0d9b57c4/src/PETSc/petscdmda.pxi?at=master&fileviewer=file-view-default#petscdmda.pxi-150
> > I do not understand why the 1st version fails.
> > Matt
> >> Thanks in advance for any assistance!
> >> Regards,
> >> -Chris
> >> Chris Eldred
> >> Postdoctoral Fellow, LAGA, University of Paris 13
> >> PhD, Atmospheric Science, Colorado State University, 2015
> >> DOE Computational Science Graduate Fellow (Alumni)
> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> Chris Eldred
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160407/f49ef722/attachment.html>
