[petsc-dev] Adding support for new sparse BLAS	inspector-executor routines in MKL
    Jed Brown
    jed at jedbrown.org
    Wed Sep 30 14:29:02 CDT 2015
Satish Balay <balay at mcs.anl.gov> writes:
> I think the issue was - blaslapack.py [as is currently organized] does
> not need or care for mkl.h.  But mkl_cpardiso.py requires it. For
> mkl_cpardiso.py to find it - it requires the -dir - or include/lib
> options.
Can one use mkl_pardiso with a different BLAS/Lapack?  If not, maybe
--with-mkl-dir= or some such to avoid repetition of the ridonculous
paths.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150930/3d99546f/attachment.sig>
