[petsc-dev] --download-petsc4py install path
    Chaffra Affouda
    chaffra at gmail.com
    Mon Sep 28 09:54:31 CDT 2015
got it. thanks.
On 09/28/2015 09:57 AM, Satish Balay wrote:
> When any externalpackage is installed with --download-package option -
> it uses the same prefix [or none] as petsc.
> If you need a different install location for any external package -
> you should install it manually - separately [and not use
> --download-package option]
> Satish
> On Mon, 28 Sep 2015, Chaffra Affouda wrote:
>> Hi,
>> Is there a way to specify where petsc4py and mpi4py are installed during
>> configure? It defaults to install_prefix/lib but that's not always convenient.
>> Cheers,
>> Chaffra
