[petsc-dev] --download-petsc4py install path
    Satish Balay
    balay at mcs.anl.gov
    Mon Sep 28 08:57:10 CDT 2015
When any externalpackage is installed with --download-package option -
it uses the same prefix [or none] as petsc.
If you need a different install location for any external package -
you should install it manually - separately [and not use
--download-package option]
Satish
On Mon, 28 Sep 2015, Chaffra Affouda wrote:
> Hi,
> Is there a way to specify where petsc4py and mpi4py are installed during
> configure? It defaults to install_prefix/lib but that's not always convenient.
> Cheers,
> Chaffra
