[petsc-dev] Error: 'ooc_nb_file_type' at (1) is not a member of	the 'cmumps_struc' structure
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Sep 25 15:51:37 CDT 2015
  Cannot explain this. Try deleting the entire PETSc directory and running again with --download-mumps send configure.log if it fails
  Barry
> On Sep 25, 2015, at 3:29 PM, Chaffra Affouda <chaffra at gmail.com> wrote:
> Hi,
> I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is mumps broken here? I am using ubuntu trusty.
> make[1]: Leaving directory `petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c: In function ‘mumps_init_file_name’:
> mumps_io_basic.c:579:14: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default]
>       tmp_dir=MUMPS_OOC_DEFAULT_DIR;
> cmumps_ooc.F:159.42:
> OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE
>                                          1
> cmumps_ooc.F:525.36:
>         DO I1=1,id%OOC_NB_FILE_TYPE
>                                    1
> cmumps_ooc.F:540.12:
> ENDDO
>            1
> Error: Expecting END IF statement at (1)
> cmumps_ooc.F:562.31:
>      IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR)
>                               1
> Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc' structure
> cmumps_ooc.F:677.42:
>                                          1
> make[3]: *** [cmumps_ooc.o] Error 1
> make[2]: *** [c] Error 2
> make[1]: *** [mumps_lib] Error 2
> make: *** [c] Error 2
