[petsc-dev] Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure
    Chaffra Affouda
    chaffra at gmail.com
    Fri Sep 25 15:29:51 CDT 2015
I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is
mumps broken here? I am using ubuntu trusty.
make[1]: Leaving directory
`petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c: In
function ‘mumps_init_file_name’:
mumps_io_basic.c:579:14: warning: assignment discards ‘const’ qualifier
from pointer target type [enabled by default]
        tmp_dir=MUMPS_OOC_DEFAULT_DIR;
cmumps_ooc.F:159.42:
OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE
                                           1
structure
cmumps_ooc.F:525.36:
          DO I1=1,id%OOC_NB_FILE_TYPE
                                     1
structure
cmumps_ooc.F:540.12:
ENDDO
             1
Error: Expecting END IF statement at (1)
cmumps_ooc.F:562.31:
       IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR)
                                1
Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc'
structure
cmumps_ooc.F:677.42:
                                           1
structure
make[3]: *** [cmumps_ooc.o] Error 1
make[2]: *** [c] Error 2
make[1]: *** [mumps_lib] Error 2
make: *** [c] Error 2
