[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
    Jeff Hammond
    jeff.science at gmail.com
    Wed Sep 23 16:32:01 CDT 2015
For what it's worth, I have actually used get_command_argument in my own
code and just now confirmed that it works just fine with Intel 16 in a
small test program.  It would be helpful to disambiguate that from all the
shared library discussion.
The other solution is to use ISO C11* as God intended and stop mucking
around with all these flowery languages.
Jeff
* It is true that no compiler yet supports C11 threads, but that is because
C compiler developers know better than to troll the PETSc team with
programming atrocities like threads.
On Tue, Sep 22, 2015 at 9:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 22 Sep 2015, Blaise A Bourdin wrote:
> > With the later configuration, it looks like what matters is the order in
> which  -lmpifort and -lifcore are listed:
> > This one works:
> > mpif90 -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
> -Wl,-commons,use_dylibs -Wl,-search_paths_first   -g -O0
> -I/opt/HPC/petsc-dev/include/petsc/finclude -o ex5f90 ex5f90.o
> -Wl,-rpath,/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib
> -L/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib  -lpetsc
> -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib
> -L/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib
> -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/mkl/lib
> -lifcore -lmpifort
> > This one does not:
> -lmpifort -lifcore
> Does linking with -lifcore vs
> /opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib/libifcore.a
> make a difference?
> And what do you have for:
> cd /opt/HPC/mpich-3.1.4-intel16.0/lib
> ls
> nm -Ao libmpiifort.* |grep get_command_argument
> BTW: I'm assuming you have sept 20 or newer petsc master branch.
> Satish
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150923/9a3643a4/attachment.html>
