[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
Jed Brown
jed at jedbrown.org
Wed Sep 23 14:42:34 CDT 2015
Satish Balay <balay at mcs.anl.gov> writes:
> There is no [easy] automatic way of figuring out this reduced link
> command that might work.
Almost all such problems are caused by shared libraries being broken or
improperly linked on too many HPC systems. If shared libraries are used
correctly, then using PETSc amounts to passing -lpetsc. If you call
another library, you also link it directly (even if PETSc also links to
it transitively). That's all. Note that almost all HPC machines are
based on Linux and that shared libraries have had well-defined
fully-functional semantics on Linux for 20+ years, so functionality is
not a matter of a new implementation, but rather just not breaking
something that works. Facilities and vendors need constant reminders
that functional and properly-used shared libraries are important.
As for PETSc, I actually attempt a simplified link line (e.g., in
FindPETSc.cmake) and only fall back to the unwieldy beast when it fails.
(This happens for static libraries, but also when shared libraries are
foobared.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150923/2fd7a281/attachment.sig>
