[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next)	2015-09-08
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep  8 23:25:52 CDT 2015
Barry,
I don't understand the commit https://bitbucket.org/petsc/petsc/commits/3dcc747d65aa2f2e79d189bef52568da19b89eea
-PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
+PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v)
   PetscTryMethod(pc,"PCTelescopeSetIgnoreDM_C",(PC,PetscBool),(pc,v));
   return(0);
This reverts the change I made earlier - which was required to compile
code [otherwise (PetscBool)(PetscInt) is flaged as compiler error]
> >>> -PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscInt);
> >>> +PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscBool);
> >>> -PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v)
> >>> +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
Satish
On Tue, 8 Sep 2015, Barry Smith wrote:
>    Done. But I may have messed up the history a little
> > On Sep 8, 2015, at 4:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Barry,
> > I see you made some changes to pr352/dmay/pctelescope/master and merged to next [and pushed]
> > However - you did not push pr352/dmay/pctelescope/master. Could you push this branch?
> > I have fix for the following warnings - and would like to push my changes..
> > [Just want to make sure all changes are in sync]
> > thanks,
> > Satish
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetKSP':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:654: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetReductionFactor':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:675: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetReductionFactor':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:696: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetIgnoreDM':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:717: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetIgnoreDM':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:738: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetDM':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:759: warning: statement with no effect
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCSetUp_Telescope':
> > /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:352: warning: 'subcomm' may be used uninitialized in this function
> > On Tue, 8 Sep 2015, Satish Balay wrote:
> >> Ok - pushed to pr352/dmay/pctelescope/master - and merged to next
> >> https://bitbucket.org/petsc/petsc/commits/bfd6bcc6ac8e2f0022fa8b00b8cd29f3a32cf260
> >> [please before further changes - or merge to master]
> >> Satish
> >>> I haven't check the examples - but I have the following fix for the build. Will push now
> >>> Satish
> >>> diff --git a/include/petscpc.h b/include/petscpc.h
> >>> index 7e583b8..0cddc86 100644
> >>> --- a/include/petscpc.h
> >>> +++ b/include/petscpc.h
> >>> @@ -324,7 +324,7 @@ PETSC_EXTERN PetscErrorCode PCMGResidualDefault(Mat,Vec,Vec,Vec);
> >>> PETSC_EXTERN PetscErrorCode PCTelescopeGetReductionFactor(PC,PetscInt*);
> >>> PETSC_EXTERN PetscErrorCode PCTelescopeSetReductionFactor(PC,PetscInt);
> >>> PETSC_EXTERN PetscErrorCode PCTelescopeGetIgnoreDM(PC,PetscBool*);
> >>> PETSC_EXTERN PetscErrorCode PCTelescopeGetDM(PC,DM*);
> >>> #endif /* __PETSCPC_H */
> >>> diff --git a/src/ksp/pc/impls/telescope/telescope.c b/src/ksp/pc/impls/telescope/telescope.c
> >>> index 5e899de..fe75c46 100644
> >>> --- a/src/ksp/pc/impls/telescope/telescope.c
> >>> +++ b/src/ksp/pc/impls/telescope/telescope.c
> >>> @@ -207,7 +207,7 @@ PetscErrorCode PCTelescopeMatCreate_default(PC pc,PC_Telescope sred,MatReuse reu
> >>>     if (reuse != MAT_INITIAL_MATRIX) { Bred = *A; }
> >>>     ierr = MatGetSize(Blocal,&mm,NULL);CHKERRQ(ierr);
> >>> -    //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr);
> >>> +    /* ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); */
> >>>     ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,mm,reuse,&Bred);CHKERRQ(ierr);
> >>>   *A = Bred;
> >>> @@ -734,7 +734,7 @@ PetscErrorCode PCTelescopeGetIgnoreDM(PC pc,PetscBool *v)
> >>>  .keywords: PC, telescoping solve
> >>>   return(0);
> >>> diff --git a/src/ksp/pc/impls/telescope/telescope_dmda.c b/src/ksp/pc/impls/telescope/telescope_dmda.c
> >>> index edd1708..98d0c7f 100644
> >>> --- a/src/ksp/pc/impls/telescope/telescope_dmda.c
> >>> +++ b/src/ksp/pc/impls/telescope/telescope_dmda.c
> >>> @@ -757,7 +757,7 @@ PetscErrorCode PCTelescopeMatCreate_dmda(PC pc,PC_Telescope sred,MatReuse reuse,
> >>>     if (reuse != MAT_INITIAL_MATRIX) {Bred = *A;}
> >>>   *A = Bred;
> >>>>  Dave,
> >>>>    I'll be fixing these.
> >>>>   Barry
> >>>>> On Sep 8, 2015, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> >>>>> Dear PETSc developer,
> >>>>> This email contains listings of contributions attributed to you by
> >>>>> `git blame` that caused compiler errors or warnings in PETSc automated
> >>>>> testing.  Follow the links to see the full log files. Please attempt to fix
> >>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> >>>>> to resolve the issues.
> >>>>> Thanks,
> >>>>> The PETSc development team
> >>>>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/6ab51f8
> >>>>> PCSemiRedundant:
> >>>>> src/ksp/pc/impls/telescope/telescope.c:116
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-opt_crank.log]
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:116:3: warning: 'subdm' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >>>>> src/ksp/pc/impls/telescope/telescope.c:210
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-c89_thrash.log]
> >>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c:210:5: error: expected expression before '/' token
> >>>>> src/ksp/pc/impls/telescope/telescope.c:380
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:380:12: warning: 'subcomm' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:112
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-opt-cxx-quad_cg.log]
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:18: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:7: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:535
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-c-exodus-dbg-builder_bb-proxy.log]
> >>>>>     /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
> >>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-valgrind_grind.log]
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda_bb-proxy.log]
> >>>>>     /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-64idx_thrash.log]
> >>>>>     /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
> >>>>>     /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-threadcomm_thrash.log]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-pgf90_grind.log]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-uni_crush.log]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-dbg-quad_churn.log]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-viennacl_bb-proxy.log]
> >>>>>     /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda-double_bb-proxy.log]
> >>>>>     /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:609
> >>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>>     /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
> >>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:760
> >>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:760:5: error: expected expression before '/' token
> >>>>> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
