[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2015-09-08
Tue Sep 8 17:27:04 CDT 2015
   Done. But I may have messed up the history a little
> On Sep 8, 2015, at 4:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Barry,
> I see you made some changes to pr352/dmay/pctelescope/master and merged to next [and pushed]
> However - you did not push pr352/dmay/pctelescope/master. Could you push this branch?
> I have fix for the following warnings - and would like to push my changes..
> [Just want to make sure all changes are in sync]
> thanks,
> Satish
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetKSP':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:654: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetReductionFactor':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:675: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetReductionFactor':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:696: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetIgnoreDM':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:717: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetIgnoreDM':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:738: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetDM':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:759: warning: statement with no effect
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCSetUp_Telescope':
> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:352: warning: 'subcomm' may be used uninitialized in this function
> On Tue, 8 Sep 2015, Satish Balay wrote:
>> Ok - pushed to pr352/dmay/pctelescope/master - and merged to next
>> https://bitbucket.org/petsc/petsc/commits/bfd6bcc6ac8e2f0022fa8b00b8cd29f3a32cf260
>> [please before further changes - or merge to master]
>> Satish
>>> I haven't check the examples - but I have the following fix for the build. Will push now
>>> Satish
>>> diff --git a/include/petscpc.h b/include/petscpc.h
>>> index 7e583b8..0cddc86 100644
>>> --- a/include/petscpc.h
>>> +++ b/include/petscpc.h
>>> @@ -324,7 +324,7 @@ PETSC_EXTERN PetscErrorCode PCMGResidualDefault(Mat,Vec,Vec,Vec);
>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetReductionFactor(PC,PetscInt*);
>>> PETSC_EXTERN PetscErrorCode PCTelescopeSetReductionFactor(PC,PetscInt);
>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetIgnoreDM(PC,PetscBool*);
>>> -PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscInt);
>>> +PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscBool);
>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetDM(PC,DM*);
>>> #endif /* __PETSCPC_H */
>>> diff --git a/src/ksp/pc/impls/telescope/telescope.c b/src/ksp/pc/impls/telescope/telescope.c
>>> index 5e899de..fe75c46 100644
>>> --- a/src/ksp/pc/impls/telescope/telescope.c
>>> +++ b/src/ksp/pc/impls/telescope/telescope.c
>>> @@ -207,7 +207,7 @@ PetscErrorCode PCTelescopeMatCreate_default(PC pc,PC_Telescope sred,MatReuse reu
>>>     if (reuse != MAT_INITIAL_MATRIX) { Bred = *A; }
>>>     ierr = MatGetSize(Blocal,&mm,NULL);CHKERRQ(ierr);
>>> -    //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr);
>>> +    /* ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); */
>>>     ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,mm,reuse,&Bred);CHKERRQ(ierr);
>>>   *A = Bred;
>>> @@ -734,7 +734,7 @@ PetscErrorCode PCTelescopeGetIgnoreDM(PC pc,PetscBool *v)
>>>  .keywords: PC, telescoping solve
>>> -PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v)
>>> +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
>>>   PetscTryMethod(pc,"PCTelescopeSetIgnoreDM_C",(PC,PetscBool),(pc,v));
>>>   return(0);
>>> diff --git a/src/ksp/pc/impls/telescope/telescope_dmda.c b/src/ksp/pc/impls/telescope/telescope_dmda.c
>>> index edd1708..98d0c7f 100644
>>> --- a/src/ksp/pc/impls/telescope/telescope_dmda.c
>>> +++ b/src/ksp/pc/impls/telescope/telescope_dmda.c
>>> @@ -757,7 +757,7 @@ PetscErrorCode PCTelescopeMatCreate_dmda(PC pc,PC_Telescope sred,MatReuse reuse,
>>>     if (reuse != MAT_INITIAL_MATRIX) {Bred = *A;}
>>>   *A = Bred;
>>> On Tue, 8 Sep 2015, Barry Smith wrote:
>>>>  Dave,
>>>>    I'll be fixing these.
>>>>   Barry
>>>>> On Sep 8, 2015, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
>>>>> Dear PETSc developer,
>>>>> This email contains listings of contributions attributed to you by
>>>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>>>> testing.  Follow the links to see the full log files. Please attempt to fix
>>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
>>>>> to resolve the issues.
>>>>> Thanks,
>>>>> The PETSc development team
>>>>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/6ab51f8
>>>>> PCSemiRedundant:
>>>>> src/ksp/pc/impls/telescope/telescope.c:116
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-opt_crank.log]
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:116:3: warning: 'subdm' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>> src/ksp/pc/impls/telescope/telescope.c:210
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-c89_thrash.log]
>>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c:210:5: error: expected expression before '/' token
>>>>> src/ksp/pc/impls/telescope/telescope.c:380
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:380:12: warning: 'subcomm' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:112
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-opt-cxx-quad_cg.log]
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:18: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:7: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:535
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-c-exodus-dbg-builder_bb-proxy.log]
>>>>>     /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
>>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-valgrind_grind.log]
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda_bb-proxy.log]
>>>>>     /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-64idx_thrash.log]
>>>>>     /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
>>>>>     /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-threadcomm_thrash.log]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-pgf90_grind.log]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-uni_crush.log]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-dbg-quad_churn.log]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-viennacl_bb-proxy.log]
>>>>>     /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>   [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda-double_bb-proxy.log]
>>>>>     /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:609
>>>>>     /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>     /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:760
>>>>>     /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:760:5: error: expected expression before '/' token
>>>>> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
