[petsc-dev] freebsd breakage
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Sep  8 11:28:16 CDT 2015
  Toby,
     This must be your pull request causing grief.
  Barry
> On Sep 8, 2015, at 11:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-cxx-pkgs-opt_wii.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-pkgs-opt_wii.log
> https://bitbucket.org/petsc/petsc/commits/e1450d8053bc869c6cfb945a2ea6dba10cadf607 is triggering this.
> sept-3: ================================================================================
> TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
> TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
>  Check that the linker can produce shared libraries
> Executing: uname -s
> stdout: FreeBSD
>                              Checking shared linker /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx using flags ['-shared']
> Checking for program /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx...found
>                                  Defined make macro "LD_SHARED" to "/usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx"
> Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-GagEyB/config.setCompilers/conftest.o -I/tmp/petsc-GagEyB/config.compilers -I/tmp/petsc-GagEyB/config.utilities.closure -I/tmp/petsc-GagEyB/config.headers -I/tmp/petsc-GagEyB/config.utilities.cacheDetails -I/tmp/petsc-GagEyB/config.types -I/tmp/petsc-GagEyB/config.atomics -I/tmp/petsc-GagEyB/config.utilities.getResidentSetSize -I/tmp/petsc-GagEyB/config.libraries -I/tmp/petsc-GagEyB/config.utilities.featureTestMacros -I/tmp/petsc-GagEyB/config.utilities.missing -I/tmp/petsc-GagEyB/config.setCompilers -I/tmp/petsc-GagEyB/config.functions  -fPIC  /tmp/petsc-GagEyB/config.setCompilers/conftest.c
> Successful compile:
> sept-8: ================================================================================
> TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
> TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
> Executing: uname -s
> stdout: FreeBSD
> Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-xTFsod/config.setCompilers/conftest.o -I/tmp/petsc-xTFsod/config.compilers -I/tmp/petsc-xTFsod/config.utilities.closure -I/tmp/petsc-xTFsod/config.headers -I/tmp/petsc-xTFsod/config.utilities.cacheDetails -I/tmp/petsc-xTFsod/config.types -I/tmp/petsc-xTFsod/config.atomics -I/tmp/petsc-xTFsod/config.utilities.getResidentSetSize -I/tmp/petsc-xTFsod/config.libraries -I/tmp/petsc-xTFsod/config.utilities.featureTestMacros -I/tmp/petsc-xTFsod/config.utilities.missing -I/tmp/petsc-xTFsod/config.setCompilers -I/tmp/petsc-xTFsod/config.functions   /tmp/petsc-xTFsod/config.setCompilers/conftest.c
> Successful compile:
> So the -fPIC is missing from the sep-8 compile - triggering this issue?
> Satish
